Old 11-11-2011
Default So I got my single stager fixed ;)
by fixed I mean had Runmc at XS make me one its a tank
build quality is a litttttle bit better then the last SS I purchased from someone else lol
will get the other one fixed up later.
should be here next week ftw. cant wait to run 32m with this instead of pouring for 6 minutes straight over and over
Old 11-11-2011
Ron's stuff is nice ..............
He ain't cheap for compressors by themselves though..........
Old 11-11-2011
ya think that build quality is better
Looking good Bro. When you get your old one back you can run the dual SB-e boards
Old 11-11-2011
lesstutrey's Avatar
lesstutrey lesstutrey is offline
lesstutrey is just getting started
Yes, my SS from ron is clean as hell with the wiring and brazing work. It's pretty much same SS, just different condensers, and routing of tubing because of that.
@Witchdoctor
How about this 24k BTU beast You just gotta have a 230 to run it on (i have one right by my benching area). Since it's R410A is can get colder than a r507 (do people just not do r410a because technically you need epa cert for it, though you can buy it on ebay). And with a tad over 2hp i'm sure it can get pretty freaking cold... pull a vacuum of 1 inch and you got -58.. of course you need a 24k btu condenser too... Just thought it would make a killer SS.. and loud too.
Old 11-11-2011
I just wish I knew how to fix Ricks cascade so I could buy it
Pretty sick condenser, but would it be worth another -10C ?
Old 11-11-2011
10C plus an extra 300W heat load
Old 11-11-2011
Well he is running a 2500k at -42c right now 1.7v sounds good so far
Old 11-11-2011
@Witchdoctor
It would not be pratical to use a 2 ton compressore and condenser
One thing could you imagine your electric bill? We are talking about a compressor large enough to cool a 1400 square foot house
A two row condensor would have to be at least 4' square with a 800 CFM fan ............
Best place for this is in an AC unit for your house
I used 410A to charge Madds SS a few weeks back ....
I think many newer units will be using it as it is easily availible and cheaper than most other alternatives.
I would not go any bigger than a 3/4 HP rotary for an SS and trust me .... they get hot and are loud
Sounds good Al, I will be checking this out this week on mine
Old 11-12-2011
Looks sick Splave. You can tell Ron takes pride is his work by how clean it is.
Old 11-12-2011
Thanks bro! You still have yours? Oh and that -42c is load temp running 1.7v 32m lol which is just what my chip needs.
