Old 04-28-2009
Default @Rogue210 Re:2d benches
I noticed at the bottom of you're recent runs you've been your head. Don't get frustrated and thx for being so active on the benchmarks.
If you need help tweaking the operating system or making tweaks to get benches to run faster, just post up a new thread in the Hwbot Discussion area and the guys would be more than happy to share some hints and tips.
Some Tips off the top of my head:
1) some 2d benches run faster if you change the windows theme to classic
2) shut down all unecessary processes including virus scanners and messengers
3) Open the app and then use cntl+alt+Delete to bring up the processes tab and kill the explorer.exe process. Once the benchmark is completed, hit cntrl+alt+delete again, new task-------- explorer.exe, this will bring the desktop back online.
4) there was another having to do with page files and stuff but I can't remember it.
Anybody else wanna chime in????????
Old 04-28-2009
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
I already shut down processes but didn't know about explorer.exe. i'll try that and the theme thing. I wish I knew more about tweeking and OC'ing my ram.
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
Old 04-28-2009
Some benches like XP more then Vista and vise versa.
Old 04-28-2009
Jeffro64's Avatar
I'll be playing more with XP when I build my new rig.... Don't want to mess around too much with my everyday rig LOL.
Main Rig
Old 04-28-2009
Rogue210's Avatar
Rogue210 Rogue210 is offline
beyond a noob
Thanks 4 the tips...newbie so it is going to take me a little while until i get the hang of it Thanks 4 the support
Old 04-29-2009
Jeffro64's Avatar
Hard to do this with Pi fast though LOL!
Main Rig
Old 04-29-2009
No thank you and Jeffro for the participation You'll get the hang of it soon enough and when you start beating personal scores you'll be hooked
Old 04-29-2009
Jeffro64's Avatar
I hope so....getting tired of getting no points! LMAO!!
Main Rig
Old 04-29-2009
XP would solve alot of your headaches :rolleyes:
Old 04-29-2009
Jeffro64's Avatar
Hmmmm.... But how does that really work over there? I mean every time I submit it is a better score than what I submitted the last time, and some things just get no points at all.
Maybe I should have started out with stock settings and one GPU and worked my way back up to where i'm at now. And using XP to start LOL!
Main Rig
