Overclockaholics Forums » Hardware Section » GPUs » General GPU » OS/Driver Install Procedure for 3D Benching
Old 11-13-2010
Default OS/Driver Install Procedure for 3D Benching
I'm sure everyone has their own way of setting up and I just wanted to share how I've been doing things. I find myself going through this procedure every time I bench a new GPU. If anyone has a better way of setting up please let me know so I can modify this lengthy procedure.
HDD: 300Gb Raptor
Full XP
1. 20gb 1st Partition Install Full XP
2. Install Chipset Drivers/Reboot
3. Install Display Drivers/Reboot
4. Install CPUZ/GPUZ/Defraggler/Riva Tuner/Afterburner/ECT.........
5. Install 3D01/3D03/3D05/3D06
6. Defrag
Tiny7
1. 20Gb 2nd Partition Install Tiny7
5. Install Vantage/Aquamark
6. Defrag
OCM
Old 11-13-2010
If you are going to be using the same motherboard repeatedly, you can always install once and make an image BEFORE installing video drivers so you can play with different versions.
Old 11-13-2010
sofos1990's Avatar
Ouch
You waste your time going this way bro .
Use a backup program and then just flash your OS . This procedure takes less than 5 minutes .
Prefer to install your OS from your original ( cough* ) cd every time you get a new mobo .
Then install the other progs and the benches and back up this partition to another HDD you have .
Do this procedure for every OS you use .
When you finish with all your OSs then flash each one to a partition that you will create .
Do not install vga drivers before the backup so you don't have to uninstall and reinstall drivers for different cards .
An HDD with many OSs ( multiboot ) is not the way I used to flash my HDDs . Kal prefers it though lol
For taking backups and flashing the images I use Norton Ghost . You can create and delete partitions through this program .
These are my images :
P.S : Install all your OSs with HT on
Old 11-27-2010
OK, got it!!!!!!
Thanks to Honda and Neuro for for walking me though it.
OCM
Old 11-27-2010
oh look images
i remember a guy using cds and dvds....from ground up..lol wasted 30minutes just doing so..lol
Old 11-27-2010
w00t!
Old 11-27-2010
OK, got it!!!!!!
OCM
What imaging software you use?
Old 11-27-2010
Image for DOS.
As simple or as complicated as you want it to be.
Old 11-27-2010
Image for DOS.
Good job teachers
Old 11-27-2010
hmmm...so can any1 explain what are the steps involved again??? I still use the normal time consuming install from CD method, :(
Already have a copy of Norton Ghost though have never used it to take backups at home. (Used it in office earlier but it was easier because all systems used to have same hardware)
