Overclockaholics Forums » Hardware Section » CPUs » AMD » Unlocking Cores in x2 and x3
Old 09-10-2009
Default Unlocking Cores in x2 and x3
I figured this guide would help some of us po' folks save a few bucks...
http://forums.techpowerup.com/showthread.php?t=102876
It seems that it's the luck of the draw on these, but the same goes for oc, so we're no strangers to the gamble. Looks like fun!
Old 09-10-2009
wow dude.... thats cool
Old 09-10-2009
Hell yeah it is. I'm thinking realistically the ability to do this is more than 50%... It has to be. AMD tests a few chip out of a batch, if too many of them have flaws then they disable the "flawed" cores in all the chips for that batch. It stands to reason that most x3 and x2 chips are worth buying for the purpose of unlocking.
If you get a bad one, YOU LOSE... HA!
Old 09-10-2009
thats cool....
Dammit i need amd setup to play with lol
Old 09-21-2009
Archer's Avatar
Archer Archer is offline
Archer is just getting started
Just try and not get pissed if it does not work!!! from what I have seen lately they are getting harder and harder to unlock and quite a few of the ones that do unlock have defective cores.
[CENTER]I am my AVATAR and YES WE have an ATTITUDE problem
905e @ 3600 1.35v | Biostar TA790GX 128M | 8 GB G.SKILL 800 ram @ 888 4-4-4-12 2T | 9800 GT EE slot power only | 320Gig WD pata Boot Windows 7 64bit | 2X160 GB Raid 0 WD Boot Vista 32bit | 2x250 GB Raid 1
CPUs are like stock PAST PERFORMANCE IS NO GUARANTEE OF FUTURE RETURNS-in other words, Expect No OC and be happy if you can OC!!!!!!!
Old 09-21-2009
Yah I posted that back when I started my 550BE unlocking thread at OCF. HAd to mention it a couple of times IIRC "Buy the chip expecting a great AMD dual core"
Lots were fortunate with that chip, but not all
Old 09-21-2009
Bones's Avatar
Bones Bones is offline
Bones is just getting started
Motherboards also play a part along with the chip since some MB's seem to do it consistently, others seems less likely to unlock the extra core(s). My MSI is one of the MB's that seems to consistently have issues with this but a few have done it.
As to the rest, no guarantees with anything so do the research and good luck.
