Overclockaholics Forums » Cooling Performance Section » DICE & LN2 Cooling » 2 K-Type Digital Thermometer w/ Thermocouple Sensors
Old 02-02-2010
Kriztoffer's Avatar
OC Alliance
Default 2 K-Type Digital Thermometer w/ Thermocouple Sensors
I've been speaking some with Neuromancer at MSN.
He linked me this darn cheap Thermometer with Thermocouple sensors..Which I'm looking for and I guess many others..
Is there any chance this thermometer could read temperature range of LN2?
LINK
Specs:
Brand new DM6802B thermometer with a portable 3 1/2 digit, designed to use external K-type thermocouple as temperature sensor.
Description:
  • Differential temperature measurement
  • Selection between celsius and fahrenheit
  • Overload display alert when input exceeds measurement range
  • Designed for use with included K-type thermocouples
  • Data-hold function
  • Temperature read-out in °F or °C selectable
  • T1/T2, T1-T2 display
Specifications:
  • Temperature range: -50°C to 1300°C ( -58°F to 1999°F)
  • Battery: 9V battery (installed)
  • Dimensions: 149 x 71 x 41mm
  • Weight: 200g ( including battery )
  • Included 2 ''K''-thermocouples
  • Resolution : 1°C or 1°F
Package Include:
  • 1 x DM6802B Unit
  • 2 x K type temperature test probe(-50 to 250°C)
  • 2 x screw
  • 1 x operating manual
slipping the clutch
Old 02-02-2010
Most of your standard temp probes are not really accurate. The unit itself is probably fine, but the K-types that come with it need to be replaced. PM Splave if he does not chime in here...he might remember the source of those from sdumper.
Old 02-02-2010
Kriztoffer's Avatar
OC Alliance
Do you know of any Ktype probes that are good?
I'll redirect him to this thread.
- kriz
slipping the clutch
Old 02-02-2010
To get really good probes will cost you a ton, they are not K-Type.
All the probes I have, maybe 8 total, 2 good ones and 6 cheaper ones all read just fine up to about -150c, good ones go to -180c.
It doesnt really matter all that much tbh.
If your chip CB's at -130c but your probe reads -128c it doesnt matter, it CB's the same anyway.
Going to max LN2 temps for me when a probe only reads to -180c just means I pour more in.
As the temps bounce around a lot you are not going to keep anything at exact temp anyway.
Old 02-02-2010
Gutterz's Avatar
Gutterz Gutterz is offline
it only says to -50c. here is a few on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
http://cgi.ebay.com/Digital-K-J-Type...34053989812854
Both say their good for -200c.
Old 02-02-2010
Kriztoffer's Avatar
OC Alliance
Jup, you are speaking the truth Buckeye. I made this thread to hear opinions from experienced people cause I don't know much about thermometers.
Looks pretty promising Gutterz, I just need a reliable meter that don't cost to much. If I could get meter that is good for -180 and avoiding the price of fluke or UFI I'm happy
slipping the clutch
Old 02-02-2010
These are cheap and work great. I have one on the cascade...
http://cgi.ebay.com/Universal-Digita...item518e2bc286
Old 02-02-2010
Me too looking for a thermometer and thinking of picking the one you posted in the OP kritz. Let me hope its decent enough till around -150C. IMO we dont need accuracy but just a fair idea about the temps. the chip and mobo can handle stably....
Old 02-02-2010
Yah. Except, add also that we want to have consistant readings from bench session to bench session. We don't want to believe that the cbb is @ -42c during session 1 and then session 2 the cold bug is -32c. That wastes ln2/dice and time.
Old 02-03-2010
Just bought one of these.... Thanks!
Also have been watching flukes on the bay. like this one:
