Old 01-24-2010
Default Suggestion for cheap DIce rig
Going to be borrowing Chuchnit's DIce pot, and I think I am about finished up with benching the ATOM setup I have, so going to get it all put together and list it on ebay.
Looking for a cheap rig that will be boint heavy
Also going to need a new PSU for my main rig. Want to get something a little larger than the 560W silverstone I am using and use the 560W for the DIce machine. My intention was to bench my 920... but it looks like it would be a lot of work for little reward.
920 at the bot 2 boints for first place in any category, and I already got 2 gold cups air cooling. So might add 4-5 points by DIcing.
Thinking Athlon II X2 240, but not sure on mobo/ RAM to get. Possibly sempron 140 although competition in both of those will be tough... would be better shot than my current stuff.
Figure I can sell my ATOM setup for about $400 beans probably so looking at $300 ish total for the CPU, Mobo, RAM and PSU.
Used is plenty fine so keep "new" pricing down below $400 for a parts list and I will do the bargain shopping from there
Thanks
Old 01-24-2010
I was planning on selling a few things
CH3
Sempron 140 - it unlocks but its hard to overclock( i think its a dud chip )
750w Corsair PSU <- in rma
was thinking of trying out P55 for a while
Old 01-24-2010
Whats a CH3?
Old 01-24-2010
Asus Crosshair 3
I'm the original owner so rma is possible
it also comes with all accessories
Old 01-24-2010
Well that board is probably outta my price range... but YHPM
Old 01-24-2010
we can do combo pricing, shoot me an offer
Old 01-25-2010
Thinking about hte TA790GX a3+ am3 board
Or should I be looking at a 775 setup?
Old 01-25-2010
I would prolly go with a 775 since PHII only scales with temps. You'd prolly get more out of 775 on dice than PHII.
Old 01-25-2010
That is true what you say, unless you are going with max LN2 temps its pretty hard to get clocks up enough for points.
Even then Intel clearly creams AMD on any bench so you would be limited to just 2D stuff.
Old 01-25-2010
Well pretty sure that a 4 GHz + range socket 775 dual core does not have the nuts to handle 3D benching either. Imma look at just 2D benching for now. Maybe later when I get another X58 setup I can go back to 3D.
