Old 11-01-2009
69_Goat's Avatar
69_Goat 69_Goat is offline
Default Jake's Sub-Zero Adventures
I had all this stuff typed once and inadvertently closed IE instead of the preview pane I was viewing.
So this time you're getting the condensed version. Probably not a bad thing because you didn't want to read all my blathering anyway.
On Friday, I picked up 10 kg of dice for my first "real" sub-zero session. I had the MB all insulated as per DrNips guide, the CPU pot (courtesy of Supes) and temp probe installed.
My plan was to improve my wPrime, 06, and Vantage scores, as those are the benches most affected by heat. Well, none of that happened. The pot just wouldn't hold the temps down. I discovered, when I tore down the setup, that I had the eraser too thick around the CPU and it was holding the pot off the chip slightly, hence the temp problems.
The experience wasn't an epic failure, as I learned alot. Like, "Don't pour Acetone through a styrofoam cup/funnel." Acetone eats it. Quickly!
I also learned, I can boot into windows at 21 x 234 @ -45C. That was as far as I got before running out of dice.
Old 11-01-2009
Minor setback, looks like it was still a fun adventure
Part 2 Should be even better, lol.
Are you overclocking at work? Looks like ur at the office!
Old 11-01-2009
Rogue210's Avatar
Rogue210 Rogue210 is offline
beyond a noob
hey supes...isn't that what happened to ur old gpu? The one that i destroyed
Old 11-01-2009
I'm not sure its destroyed yet but yah, the eraser on that gpu you insulated was too high and prevented good contact between the gpu block and the gpu. Same smell.
Old 11-01-2009
69_Goat's Avatar
Yeah, it was alot of fun. With more experience I should be able to reduce the NOOB mistakes, or just make different ones.
I do all my benching in my office.
After hours, of course.
Old 11-02-2009
karmakazi's Avatar
great start! subzero is something that grows on you each time you do it (at least ofr me). Everyone makes some mistakes in the beginning, but thats how you learn the fastest. My first mistakes were alot more costly than yours, I killed 2 great chips and a motherboard
Old 11-02-2009
HAHA I did the same thing my 1st go around with a styrofoam cup. Nice setup and nice boot up clock.
Old 11-02-2009
I can't wait to take that plunge Going to have to do it one something other than an i7 though LOL
Old 01-11-2010
Kriztoffer's Avatar
OC Alliance
Originally Posted by 69_Goat View Post
The experience wasn't an epic failure, as I learned alot. Like, "Don't pour Acetone through a styrofoam cup/funnel." Acetone eats it. Quickly! .
Haha
Nice setup man!
Maan, I can't look at pictures with 4870x2's I miss mine so freaking much. I had two Sapphire cards this summer..I miss them. Think I need to buy one again.
slipping the clutch
Old 01-11-2010
Is that Playdo you used ?
Some say that stuff doesnt work to well, can you get Art Eraser ?
