Overclockaholics Forums » Welcome to Overclockaholics » Hardware/Software News » A-data 2200mhz DDr3 Dual Channel cas 8
Old 07-27-2009
Default A-data 2200mhz DDr3 Dual Channel cas 8
Originally Posted by techpowerup.com
A-DATA Unveils New XPG Plus Series DDR3-2200+ v2.0 with 2oz Copper PCB Design
A-DATA Technology Co., Ltd., a worldwide leading manufacturer in high-performance DRAM modules and flash application products, today announces its new XPG Plus Series DDR3-2200+ v2.0 dual channel kit, which is the highest speed of DDR3 DRAM module in the industry.
The XPG Plus Series DDR3-2200+ v2.0 DRAM module is designed and guaranteed to run on future dual-channel platforms at incredible 2,200MHz killer speed with tight CL8-8-8-24 timings at a voltage of 1.65V, and are available in 1GBx2 and 2GBx2 dual-channel kits.
Through the latest Thermal Conductive Technology (TCT), the XPG Plus Series DDR3-2200 v2.0 DRAM module is built with the superior cooling design, which able to provide greater cooling environment for both DRAM IC and PCB (printed circuit board), to improve the performance and greater stability. Moreover, the doubling amount of copper in the PCB delivers low temperature and also improves the power efficiency for the XPG Plus Series DDR3-2200 v2.0 DRAM module.
"Demand for the higher PC performance continues to increase and A-DATA is the leader in this field with the XPG DRAM products. We created XPG Plus Series DDR3-2200+ DRAM module to lead PC enthusiasts into the next era of PC performance and satisfy their insatiable thirst for computing speed," said Action Chen, Deputy Project Manager of A-DATA XPG. "The new XPG Plus Series DDR3-2200+ DRAM module delivers the killer speed and reliability of all DRAM module currently on the market."
"GIGABYTE Ultra Durable 3 motherboards GA-P55 series and A-DATA XPG Plus series memory featuring 2 ounces of copper PCB layers, enable a dramatically lower system temperature, improved energy efficiency and enhanced stability for overclocking" mentioned Jackson Hsu, Product Manager of GIGABYTE.
The XPG Plus Series DDR3-2200+ v2.0 DRAM module is the best choice for the PC enthusiasts to achieve the greater performance and stability, to satisfy their insatiable thirst for computing speed.
Features
  • <LI itxtvisited="1">All DRAM IC are verified by overclocking criteria. <LI itxtvisited="1">High-quality 2oz copper 8 layers PCB (Printed Circuit Board) <LI itxtvisited="1">Optimized for 64-bit OS (operating system) <LI itxtvisited="1">Backward compatible with DDR3-1866, 1600, 1333 and 1066
  • Lifetime limited warranty
Specification:
  • <LI itxtvisited="1">2GB/4GB dual channel module kits are tested at 2200MHz <LI itxtvisited="1">Test at latency setting 8-8-8-24 at 1.55V-1.65V
  • SPD (Serial Presence Detect) programmed at JEDEC standard DDR3-1333 with latency settings at 9-9-9-24 for basic system booting
  • techpowerup.com
Old 07-28-2009
ADATA has put out some screamin RAM. I just wish I could get my hands on some. I just hope they put a disclaimer with this so some idiot won't be over at some other noobish forum asking why he can get his to run 2200MHZ prime stable for 8 hours. Somethin like "Don't buy if you are an idiot, nooobish or think it is as simple as plug and play at 2200MHz on air!!!"
Old 07-28-2009
Deux's Avatar
Deux Deux is offline
Deux is on a distinguished road
Seems a bit early for P55, suppose they just want to be first.
I'll be interested to see how these play at Cas6 as they are one of the few dual channel kits that should be Hyper.
Old 07-28-2009
I'll be interested when I can actually get my hands on some.
Old 07-28-2009
WOW
Can anything but an i7 actually be effected by RAM this speed?
I mean, can AMD or C2_ actually utilize that kind of bendwidth yet?
Reason I ask is because it is sold only in dual channel kits, saw no mention of triple channel.
(And I do not think that AMD can run that high a Mem speed period, Chew is running 1800+ now, and the thread made it seem like a big deal that it was that fast on an AMD system...)
Old 07-28-2009
karmakazi's Avatar
@neuro- I think its meant for P55 chipset... which is dual channel but should be able to achieve high speeds. I have hit 2200 8-7-6-18 on my 790i with a 8600, so some C2D can utilize it.
@Kal- I dont think ADATA can sell in north america. Its mainly available in Asia with some Euro stores getting a few kits here and there.
Old 07-28-2009
Yep, and I've always wanted a set from these guys. Have you played with their ram before?
Old 07-28-2009
Are they going to be available in the US. There other 2133 kit can't be found here or at least I couldn't find it.
Old 07-29-2009
dinos22 dinos22 is offline
dinos22 is just getting started
why early
Old 07-29-2009
Same here Kal, I have some chips that could really use the extra speed of these bad boys.
