Old 07-24-2009
Default Just goofin
Tried this experiment the other day with mixed results. Two 110 cfm fans on GTX 280's. I improved on most bench's with a 8600/790i Ultra combo, but the card in slot #1 still got pretty hot. Most likely because of the thickness of the fans...as you can see it butts right against the adjacent card.
Old 07-24-2009
Outlaw Outlaw is offline
Outlaw is just getting started
Are those tornado fans?
I never realized that there was that much room between the 2 cards.
Intel E8600
XFX260GTX
Corsair 750W
Asus Max Formula
D-Tek V1 CPU water Block
Kingston HyperX PC8500 4x1g
XSPC Full Coverage Video Card block
All tucked in my ThermalTake full tower
Old 07-24-2009
filmbot's Avatar
filmbot filmbot is offline
filmbot is just getting started
If I'm correct, 780i was one of the boards with really nice PCI-E spacing, so I'm assuming theres another slot in between there.
Old 07-24-2009
Yes, those are Vantec Tonado's. Very thick fan too.
You should rig up an air duct for the top card, and have the fan parallel to the motherboard. Pretty sweet mod though.
I agree...the fans are just too thick to work well in that configuration.
Yes, there is another slot in between the two. That pic is of a 790i Ultra SLI mb.
Yeah you might try smaller width fans see if you don't get better results.
Yep Nip - I will be doing just that in the near future.
Old 07-24-2009
Gunslinger's Avatar
Overclockaholic
Old 07-24-2009
Old 09-24-2009
Haha, missed this one, nice bully mod bro
