Overclockaholics Forums » Overclocking Section » Overclocking » 20x Linx Stable i920 HT runs
Overclocking Air & Water...
Old 07-22-2009
Cecil Cecil is offline
Cecil is just getting started
Default 20x Linx Stable i920 HT runs
Lets see some.
Ive got 4.2HT as my "sweetspot". Lowered every voltage as much as possible, and tightened everytiming as much as they would go.
920 D0 - 4200Mhz - 1600Mhz - 8-8-7-21 - 1.33VCore - 1.265VTT - 1.6VDimm - Auto everything else - Water - 35C/74C
Working on more.
Old 07-22-2009
2chesapeakes's Avatar
I tried running this on my R2E with the 965 all settings stock. Instant blue screen every time. Don't know if I had a setting messed up or what but gave up.
Old 07-23-2009
hellcamino's Avatar
That means you are unstable as hell Jeff...LOL! Good thing you aren't benching it at stock!
Old 07-23-2009
Got 4.3HT now, working on some more.
920 D0 - 4300Mhz - 1640Mhz - 8-8-8-24 - 1.3875VCore - 1.325VTT - 1.6VDimm - Auto everything else - Water - 36C/83C
Old 07-24-2009
920 D0 - 4405Mhz - 12600Mhz - 8-8-8-24 - 1.5VCore - 1.5VTT - 1.6VDimm - Auto everything else - Water - 40C/89C
Still working on this one a bit.
Old 07-23-2009
I'll try and get one for ya tonight Cecil. I ran 5 passes easy at 4198mhz 1.28vcore loaded. Memory needs work though so I'll be spending my time on that.
Old 07-23-2009
69_Goat's Avatar
69_Goat 69_Goat is offline
Here's a run I did recently
920 C0 - 4000Mhz - 1600Mhz - 9-9-9-24 - 1.35VCore - 1.318VTT - 1.66VDimm - 1.86CPU/PLL - Auto everything else - Water - 25C/82C
If I had a Rad in my cooling loop, my temp delta wouldn't have been so wide.
With better control of temps I could get a 4200 Mhz pass. I was 70 min. into a run and got an error.
Old 07-24-2009
Nice 4.45 run but ouch with the volts and temps!! Can you get the volts any lower?
Old 07-24-2009
Working on it. I spent about 5 hours trying to get it stable, then said screw it and pushed them all too high.
Old 09-07-2009
Chicken Patty's Avatar
Originally Posted by Cecil View Post
Lets see some.
Working on more.
very nice man. You sure you can't get your vcore down more? Here is mine.
This was tested also few hours of prime and went on to crunch about another day and a half at those settings.
Total Threads = 12
