Overclockaholics Forums » Overclocking Section » Overclocking Utilities/Benches » Guru3D Driver Sweeper 2.0.0 Final download released
Old 07-22-2009
Exclamation Guru3D Driver Sweeper 2.0.0 Final download released
By Hilbert Hagedoorn, July 22, 2009 - 6:52 PM
Guru3D - Driver Sweeper is a fast tool to remove driver leftovers from your system. Driver Sweeper is very easy to use. You only have to select the drivers you want to clean.
The best way to clean drivers is to first uninstall the drivers using the official uninstallers, reboot in Safe Mode and run Guru3D - Driver Sweeper. However, rebooting and not going into Safe Mode also works, but can cause some files not to be cleaned.
What can it be used for ?
The current supported drivers are NVIDIA (Display and Chipset), ATI (Display), Creative (Sound), Ageia (PhysX), MMouse and Realtek (Sound).
All the settings are saved in an ini file. Nothing is created in the registry, so it's possible to use it as a portable program. Log files can be saved to the harddisk and viewed as well. You can find the logs under the Tools menu.
System requirements:
The Guru3D - Driver Sweeper is fully tested on Windows 2000, XP, Vista and 7 (final).
Both 32-bit and 64-bit versions are supported.
More info and revision history can be found here:
* Official Guru3D - Driver Sweeper homepage click here.
* Official Guru3D - Driver Sweeper forums click here.
Most important changes since 2.0.0 beta (complete rewrite):
* UAC message requiring administrator access on Windows Vista and Windows 7 on startup if UAC is enabled.
* Resizable window.
* Lowered requirements to .NET 3.0.
* Windows 7 support.
Only the final version is supported.
* Updated:
- Improved ATi - Display cleaning.
- Improved NVIDIA - Display cleaning.
- Improved NVIDIA - PhysX cleaning.
- Renamed AGEIA - PhysX to NVIDIA - PhysX
* Added many translations
Download:
* Guru3D - Driver Sweeper (Setup.exe)
* Guru3D - Driver Sweeper (binaries)
SOURCE:
http://www.guru3d.com/news/guru3d-dr...load-released/
Old 07-22-2009
Thx buddy.
Old 07-22-2009
very cool tool...
shoudl we have a specific section for tools and stuff?
Old 07-22-2009
You're in it homie
Old 07-22-2009
ummm wow... ill just say i knew taht and pretend like i was testing you
Old 07-22-2009
hehe
Old 07-23-2009
eva2000 eva2000 is offline
eva2000 will become famous soon enough
reminds me of CCLeaner ?
Old 07-28-2009
karmakazi's Avatar
Nice to see they updated this one! With the newer drivers it wasnt removing everything...
Old 07-29-2009
Shahryar_NEO Shahryar_NEO is offline
Shahryar_NEO will become famous soon enough
Thanks mate .
some weeks ago i got a really bad IRQ conflict and it relieved me .
Old 07-29-2009
sofos1990's Avatar
thnx for sharing buddy!
Has anyone try it?
