Old 03-07-2009
Default Vdrop/Vdroop
Vdroop Technically Explained
Vdrop is the difference in voltage you get from what you set in the BIOS, to what you get in windows at idle.
Vdroop is the difference in voltage you get from what you set in the BIOS, to what you get at load in widows or as some will say the difference from idle to load.
Originally posted: drnip
Old 06-28-2009
Ok, so is it better to leave VDroop on or off?? On ASUS boards I believe it's called Line Calibration.
Some tell me it's best to leave VDroop off?
Old 06-28-2009
limpkorn's Avatar
limpkorn limpkorn is offline
Junior Addict
limpkorn is just getting started
I've always had best overclocking results by leaving vdroop off.
Usually when you set Vdroop on you have to crank up more voltage in the bios.
Thermaltake Spedo Advance
EVGA X58 Classified NF200 Version
Core i7 920 4.4Ghz w/ Koolance CPU-350 Water Block
Mushkin Redline 3X2GB 2000mhz 8-8-7-24-T1 Kit
SoundBlaster X-Fi Titanium Fatal1ty Professional
WD 300GB 10K RPM VelociRaptor X2 in RAID 0
Seagate Barracuda 1TB HD
3XEVGA GTX 280 in SLI TRI-SLI w/Koolance Vid-428 Water Blocks
Ultra X3 1000W Power Supply
FPS X5 450Watt GPU PSU
G11 Gaming Keyboard G5 Gaming Mouse
Samsung Syncmaster 2493HM Monitor
Old 06-28-2009
I've always left it off on my Classified, but always had it turned on on my R2E .. possibly one of the reasons the R2E hasn't been a very good match with the 920 D0 I put on it
Old 06-28-2009
2chesapeakes's Avatar
I use it on the classified, the R2E, and the RE but none of these boards are 24/7 use. I usually try and boot in with the minimum amount of volts set in bios and like the the extra boost there when I am benching. I have also noticed I could set less volts in bios and this non droop would kick in while windows was booting. I think it is an excellent feature of any board.
Old 06-29-2009
Deanzo Deanzo is offline
Champion
Deanzo is on a distinguished road
For socket 1366, it doesn't seem to help me any.
But for socket 775, using a vdroop mod and or load line calibration was a must most of the time.
Old 06-29-2009
dinos22 dinos22 is offline
dinos22 is just getting started
i donno man
at very high clocks on LN2 hitting the right vcore sweetspot is very important iwth i7
i think its very important particularly on boards that dont have as strong a power circuitry as Classified does
Old 06-30-2009
Vivi's Avatar
Vivi Vivi is offline
Planning my comeback..!
the droop/drop on some GB boards are sick
Vdroop mods are good for sure, cpu's dont like being thrown random voltages, or so it seems
Old 07-01-2009
karmakazi's Avatar
Ive had a mixed bag of results concerning enable/disable it. Sometimes it has helped and other times its no good at all. I havent found a pattern to it yet tho.
Old 07-13-2009
youngpro youngpro is offline
youngpro is just getting started
meh it helps me thruogh 06 on i7 a little.. but in 05 i get better results with it off, guess its something you have to experiment with and different for each manufactuer
