Overclockaholics Forums » Overclocking Section » Volt Mod's » RV790 Volt Mod Soft/Hard
Old 07-01-2009
Question RV790 Volt Mod Soft/Hard
Lookin for anything and everything RV790 volt mod related. Be it a soft or hard get it posted if you don't mind. I prefer a soft mod as a simple bump in volts is prolly all I need but will take anything.
Old 07-01-2009
Anyone know if this will work?
http://www.techpowerup.com/downloads...tor_v1.21.html
Old 07-01-2009
crio's Avatar
crio crio is offline
Why wouldn't it work.But be aware that bios wot give more than a little more juice.Nothing special.
Post a pic of both side of the card in HQ
Crio OC
Old 07-01-2009
Lookin for somethin to give me about 1.4v.
Old 07-01-2009
Just bought myself a DMM today, tonight going to be pencil modding my 4850. If it works well I will upgrade to a hard mod (assuming I can keep it cool enough in this heat :( )
This is all I could find about modding the 4890.
Few links there which is why I linked the post rather than the XS thread. (
Hope that helps (says 4870, but should work on the 4890???)
Old 07-01-2009
crio's Avatar
4890 works great with rivatuner+voltage factory but requires the patch.I think Neuromancer's link is the one containing the wright things
Crio OC
Old 07-01-2009
Yeah I couldn't get Rivatuner to work. I will have to check into this when I get my RAM back.
Old 07-01-2009
So much for the pencil mod. One card dead.
Old 07-02-2009
limpkorn's Avatar
limpkorn limpkorn is offline
Junior Addict
limpkorn is just getting started
I'm going to be following this thread as I too am interested in a voltmod for the HD4890's.
Sorry you killed you card Neuromancer, can it be rma'd?
Thermaltake Spedo Advance
EVGA X58 Classified NF200 Version
Core i7 920 4.4Ghz w/ Koolance CPU-350 Water Block
Mushkin Redline 3X2GB 2000mhz 8-8-7-24-T1 Kit
SoundBlaster X-Fi Titanium Fatal1ty Professional
WD 300GB 10K RPM VelociRaptor X2 in RAID 0
Seagate Barracuda 1TB HD
3XEVGA GTX 280 in SLI TRI-SLI w/Koolance Vid-428 Water Blocks
Ultra X3 1000W Power Supply
FPS X5 450Watt GPU PSU
G11 Gaming Keyboard G5 Gaming Mouse
Samsung Syncmaster 2493HM Monitor
Old 07-02-2009
Well I decided to keep my cards as
1. I am tired of RMAing
2. There not really bad cards, just 1 is better than the other 2
3. Goin to make em work
As soon as I get some RAM I will be incorporatin some of the info in this thread.
