Overclockaholics Forums » Cooling Performance Section » Water Cooling » My water/peltier bench station
Old 06-29-2009
Josifek Josifek is offline
Josifek is just getting started
Default My water/peltier bench station
Hi all !
Here is my newest project im working on...
Viscool CPU block
Pump: 3000l/h
RAD out of car heating
2x Sunon 220CFM 4000rpm FANS
400W Peltier powered from forton booster X
Expansion tank made of food storage box
And of course some PVC tubing soon to be replaced by pressure tubing
Here is the peltier power supply
I had to put on double 1mm high current wiriing because it was getting so hot that i couldnt touch it... No way a molex could survive this ampere ownage...
Here is a size comparsion of my new pump to sicce micra
And my car heating radiator with custom cardboard shround
Also "killer fans" as i like to call them... no way im turning theese on without a grill
Currenty I am doing 7*C idle and 12*C load on my 2800+ Sempron on 1,65V but I am held back by the radiator and the CPU block.
And the whole setup:
