Overclockaholics Forums » Hardware Section » CPUs » Intel » Any other i950 bros here?
Old 06-22-2009
Default Any other i950 bros here?
Any one else have i950s here if so what have you hit?
Old 06-22-2009
If I had one, I'd say "you first". Watchya gots?
Old 06-22-2009
RomDominance's Avatar
You know its just a matter of time bro. The reason the Empire issued that warpcore tech to you first, your prototype Warbird sports the Breen plasma coolant.
Old 06-24-2009
5.1ghz max so far on ss, didnt have much time to toy though is there ever enough time?
Old 06-24-2009
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
Nope.... never ever enough time.
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
Old 06-24-2009
Isn't that the truth.. haven't even played with my new SS yet. :mad:
Old 06-27-2009
spfoam1's Avatar
spfoam1 spfoam1 is offline
Lurker
Since my i7 975 arrived as a paperweight, I had to install the i7 950.
I have all the luck with the DOA shit......
Anyhow, I just got windows up and running with the i7 950 last night. I have it air cooled with a Mugen II cooler and it runs 4.1 GHz with 1.2v, 4.46 GHz with 1.34v. I have only tinkered with it for about 2 hours. I haven't run any benches, and I only ran prime for a short time to get a feel for general stability. Not bad on air cooling so far. Probably not a"cherry chip" but it's a decent one. I'm sure it will like the SS.
I have no time. :(
Old 06-27-2009
I have no time. :(
Music to my ears Foamer
Old 06-27-2009
From my experience's so far with my 950 I can tell you I will not even consider a 975. This chip just continues to blow my mind (and the bot).
Old 06-28-2009
dinos22 dinos22 is offline
dinos22 is just getting started
trouble with these bloody CPUs is that multi
Intel's even multies are pretty buggy :(
you should use 23x instead for OCing. It will probably yield better results
