Overclockaholics Forums » Hardware Section » CPUs » Intel » 5960x OC Settings for 4.7ghz
Old 09-08-2015
Default 5960x OC Settings for 4.7ghz
Posting compressed zip file of oc settings for 24/7 4.7ghz exported off my 5960x and Rampage V Extreme for one of our members to tinker with.
Download file, properties, unblock, unzip, load .cmo file to a usb, reboot, enter bios, oc save/profile settings, load from usb, locate file, load as per directions.
Load the settings and go thru the settings pages to change miscellaneous storage, motherboard settings that may have been loaded in addition to voltage/mhz settings.
Also adjust Memory timings and XMP settings as needed for your specific setup.
As with any chip, mhz may vary.
Old 09-08-2015
How are temps when loading all cores ?
May be water cooling x99 soon
Old 09-08-2015
Gimme a few minutes to run aida64 stability test with temperature statistics. brb
2 minute stress test load with temps on aida64.
Hottest core#3 at 73c. Anything beyond this duration is fully dependent on the heat capacity of your radiator system, of course.
Old 09-09-2015
Not bad at all , no luck with less volts ?
Old 09-09-2015
lakeside2189's Avatar
Thank U super star!!!!!
Old 09-09-2015
Haven't tried, it worked so I didn't fix it.
Old 04-28-2016
Denis Denis is offline
Denis is just getting started
Hi all! Kal-EL, I can't load your profile in BIOS. BIOS v2001, DDR 2133. Can you help with this? Thanks!
Old 04-28-2016
Whats happening exactly?
Old 04-28-2016
when i try to load setup from usb it say that can't do this
Old 04-29-2016
unzipped the file first?
