Overclockaholics Forums » Software Section » Vista » Vista x64 and 3Dmark06 fixes
Vista The Comeback Kid...
Old 06-15-2009
Default Vista x64 and 3Dmark06 fixes
It seems that there are some users that can't get 3DMark06 to run in Windows Vista, and namely in Vista 64 bit. Here are some steps you should take in case you can't get 3DMark06 to run:
1. Please only use our official mirrors if you are about to download 3DMark06. We can't control what other un-official sites are hosting. Check our official mirrors from here: http://www.futuremark.com/download/3dmark06/
2. Make sure that the version of 3DMark06 is 1.1.0 (latest one)
3. You need to install everyting that comes with the 3DMark06 installer (OpenAL, DX Update and obviously 3DMark06)
4. If you are running Vista 64 bit you will also need to install a separate OpenAL installer:
http://developer.creative.com/articl...&top=38&aid=46
5. In some cases (we haven't been able to reproduce them in our labs) the DX update doesn't install or install correctly. It is required to install it for 3DMark06 to run, so please download the latest DX updated here:
http://www.microsoft.com/downloads/d...displaylang=en
6. Install the latest available WHQL drivers from your graphics card vendor (FM Approved prefered)
Another thing you may want to look into in case you are experiencing "Lost Device" errors in Vista when running 3DMark06, is Vista's TDR (Timeout Detection and Recovery). You can find more info about it (and how to disable/edit it) here:
http://www.microsoft.com/whdc/device...m_timeout.mspx
Please note that playing around in your registry is not recommended unless you have experience with it.
Source
Old 06-15-2009
Interesting. I never had any probs but good to know Nick[FM] is in your corner!
Old 06-15-2009
hellcamino's Avatar
When installing I always have to uninstall openAL as the app fails to launch, restart and then install openAL and it works perfect.
Old 06-15-2009
Hmm, never had any problems but haven't had vista for very long.
Old 07-01-2009
Crysis's Avatar
Crysis Crysis is offline
Crysis is just getting started
Same here, I've used Vista 64bit for a while and nothing went wrong...
I am however having some issues with CPUZ 1.51 on Vista 64bit, nothing is getting validated when I submit CPUZ files. Quite interesting...
Intel E8600 @ 4.0Ghz 1.2v l TRUE l ASUS Maximus Fornula X38 l 4GB DDR2-800 Mushkin @ 4-4-4-12 l HD4870 Gecube l 750GB HDD l Enermax Modu82+ 625W Mod l Gigabyte 3D Mars l Logitech G15 l Logitech G9 l Logitech Z560 l Samsung 2263UW
Old 07-01-2009
This may souhd silly but have you attempted to run the cpuz in compatability mode to get the validation to go thru?
Old 07-01-2009
Crysis's Avatar
I dont actually know how to do that...
Old 07-01-2009
Right click the executable for cpu-z, click properties, compatability tab, then select xp32 or something along those lines.
It must be the executable file for cpuz, if you did the full install of the latest version you'll have to go dig thru the program folders to find the source file.
Old 07-01-2009
Crysis's Avatar
Hmm, well I'll try that once I get my system running, waiting for some new ram to arrive...
Old 07-01-2009
ViViD ViViD is offline
ViViD is just getting started
Tanx Men
But With 4Gig Ram Not Diffrent Btw XP 32 And Vista 64
I Tested 06 In Vista 64 And Then In Xp32
Diffrence Btw 500 Or 400 Scores
Any Issue For Get Higher Score In Vista 64Bit With 4Gig Ram?
