PSUs Lets Talk Power...
Old 06-15-2009
Peen Peen is offline
Peen is just getting started
Default Corsair HX750W
Anyone have one of these yet? Mwave has on for $149 they are brand new and think I might buy one.
Old 06-15-2009
hellcamino's Avatar
I think you can get better prices from newegg
PC P&C 750
http://www.newegg.com/Product/Produc...82E16817703009
Corsair 750
http://www.newegg.com/Product/Produc...82E16817139006
I would get the PC P&C myself if getting a 750w range PSU although the Corsair is also a fine unit, what are you looking to power with this?
Old 06-15-2009
Powering Core I7 Xeon, 6Gig ram, 4850X2, 3 HD's, case fans. Well the HX750 is modular and maybe better quality PSU then the TX750. I think it's more like the HX620
Old 06-15-2009
hellcamino's Avatar
I think you need to get away from these little PSU's, get the Corsair HX1000 (if you like Corsair) for your pc and you won't be straining it to the point of melting connectors. What PSU were you using previously?
Old 06-15-2009
You need to plan for on down the line. I recently got out of my rut of buying PSU's. I started with a 600w. Not enough power so I bought a 750w. It in the end didn't have enough pcie cables so I bought a 850w. It had enough pcie connects but not enough power for what I had in mind as I planned on going subzero with quad GPU's so I was going to buy 1000w but went with the 1200w just incase I needed it in the future. I would go with at least a 1000w with plenty of pcie cables.
Old 06-15-2009
Yeah I would love to have one but my budget isn't much over $100 so even the $150 is pushing it. Plus my 2 day old board died, and I need to replace that too. But I won't even touch it till a new PSU is connected to it
Just ordered a 850HX it's supposed to be the shizzz. Even though I didn't really have money for one...
Old 06-21-2009
RomDominance's Avatar
Put that psu in my son's rig 3 monthes ago, and it has been fantastic. Best of luck bud.
Old 06-21-2009
This PSU just came out, it's modular like the 620HX and 1000HX
Rig 1: Xeon W3520 4.4Ghz HT, DFI UT X58-T3eH8, 12GB OCZ, Radeon 4850X2, Corsair 850HX, 2TB RAID, 32" HDMI, Vista x64
Rig 2.5: *SOLD* Q9550 3.8ghz, MSI P45 Neo3-FR, 8GB Corsair
Rig 3: 1.6Ghz Pentium Dual Core, 3GB G.Skill, 120GB HD, Win 7 x64
Rig 4: Pentium 4E 4Ghz, MSI P865, 1GB DDR, X850XT AGP, Windows XP Pro
Old 06-22-2009
I love modula, really makes it easy to tidy the cables
Old 06-30-2009
<<HANNIBAL>>'s Avatar
<<HANNIBAL>> <<HANNIBAL>> is offline
<<HANNIBAL>> is just getting started
I have got TX750W and tho only con in that it's not modular
so the HX750W will be the best choice for price/performance
