Overclockaholics Forums » Cooling Performance Section » Air Cooling » Need suggestion's on a high wattage fan controller
Air Cooling Air Powered...
Old 03-28-2014
PhIlLy ChEeSe's Avatar
Default Need suggestion's on a high wattage fan controller
Title says it all, I need a fan controller that for 1 aint junk 2 will power many fans, 3 I don't care about looks.
Got to handle many fans like 9 atleast
Old 03-29-2014
what is the wattage of the fans ?
Sunbeam makes one with 4/20 watt chanells at a decent price point
http://www.frozencpu.com/products/10...FewDOgodwWQA9A
Old 03-29-2014
That's the thing, I don't know the wattage? I may put two rads of fans so six fans, how do you figure out the wattage?
Old 03-29-2014
the fans should have a rating on them, if not stick the models in Google and get it
here is a 30 watt per channel
http://www.newegg.com/Product/Produc...82E16811995075
on mine I can for 4x fans off each Channel
I have two of these for my gaming rig
http://www.newegg.com/Product/Produc...82E16811997084
