Old 03-19-2014
runmc's Avatar
runmc runmc is offline
runmc is just getting started
Wink Under the Ice for Philly Cheese
New build for Philly Cheese - Lots of pics. All new parts.
Let's start off with Big 3/4 hp condenser
3/4 hp Danfoss Compressor
Evaporator brazed up
Flex line brazed to evap
Cap tube coming up
Water bath to check for leaks
Evap is pressured at 250psi to check for leaks while bathing
I like to wrap the cap tube around flexline for added subcooling, then add rubber tape to secure cap tube to flex.
Big fat insulation
My work bench
I add a piece of copper around the joint where the flexline and copper meet. This is a spot where leaks can possible develop over time.
Closer look at splint
Unit is all brazed up now and pressure testing. I have more pictures but I need a break from uploading for lunch.
