Air Cooling Air Powered...
Old 06-13-2009
Talking Megahalem is Here!
Yep the usps was kind enough to knock on my door with a little Saturday surprise. Now I just gotta finish some stuff up around the house so I can install it. It is huge so I sure hope it does better than my stupid Zalman 9700
First Look
Old 06-13-2009
Jeffro64's Avatar
Jeffro64 Jeffro64 is offline
You got one! Did you get fans for it?
Main Rig
Case - Cooler Master Cosmos S
PSU - Corsair HX1000 1000W
DVD - LG 22X GH22LS30
OS - Vista Ultimate 64bit
Old 06-13-2009
Yep. Right now I just have a single 75cfm "Kaze Flex" made by Scythe. I'm gonna order some 38mm clips and a panaflo to do a comparison. Frank and I have a little disagreement so we are gonna find out who'd right.
Old 06-13-2009
Jeffro64's Avatar
TBH... I had 2 panaflows in PP and it was only a few degrees C less than the stock cooler that came with my chip. And my Megahalem is lapped. It is a nice cooler but I expected more from it after reading reviews on it.
Main Rig
Old 06-13-2009
Well a couple weeks ago I found every review I could of the top aircoolers. Alot of review sites are either biased or just have shitty testing methods. The megahalem honestly doesn't shine until the heatload is increased. It will perform about the same as most coolers for "normal" use. It's when you really add the vcore, or put an i7 under it that it truly shines. Try the stock cooler on your 920 and then put the megahalem on there. You'll see what I saw in the reviews.
Old 06-13-2009
Kool man, Thor's Hammer is almost here too.
Old 06-13-2009
I'll take Thor's hammer and shove it up his arse :p
Old 06-13-2009
Jeffro64's Avatar
Yeah... I plan on starting with air again so I will give that a try. I don't plan on lapping my 920 so I hope it is pretty flat to start with.
Main Rig
Old 06-13-2009
What is ur fixation with anus????? :confused::confused::confused::confused:
It'll be a first hand account of how the Thor's Hammer runs dippidy poo dah man! Welcome it no matter what ur little review friends say.
Old 06-13-2009
the cooler will not greatly benefit from high CFM but more from static pressure from what I have seen, Try getting a good 38mm fan and make sure its mid-low speed, and i bet youlle get the results your looking for
