Overclockaholics Forums » Hardware Section » Motherboards » Intel » Microcenter GA-Z87X-UD4H
Old 06-08-2013
Default Microcenter GA-Z87X-UD4H
Starting this thread for a friend.
The Screenshots below are done on air cooling. I was able to run 3Dmark 06 @ 3.5ghz and memory @ 8-9-8-24 2200MHz. This kit is rated for 9-9-9-24 2000MHz. I saw an overall gain of 800-1k points in the CPU tests over the 3770k at the same clocks.
I will add results with board under Dry-ice shortly.
Old 06-12-2013
danmoody danmoody is offline
danmoody is just getting started
Thumbs up max clock?
how high did you get this thing up to? I put in i request for the oc formula and the micro oc formula yesterday so I hope they come in
Old 06-12-2013
So far 5.5ghz on Dry-ice temps but that was with stock Bios F5 which was a little buggy. So ill be trying again tomorrow with bios F6b. I've already flashed it and seems to be a lot smoother for Overclocking, it also has more adjustable with Uncore.
Not sure which OCF board i want out of the 2, might depend on pricing.
Do you have any newer batch numbers at the store for 4770k?
