Suggestions Have An Idea...
Old 03-04-2013
Default Troubleshooting
A troubleshooting section. Along with mandatory syustem specs. It's impossible and frustrating to solve pc problems without knowing the system specs. And i see help questions all over the place. I think we need to contain them. Thoughts?
Old 03-04-2013
This good enough?
Old 03-04-2013
Thats awesome!!!
Did you just add that or was it there and i never saw it?
Old 03-04-2013
Thats awesome!!!
It was there, just under utilized or un noticed so I changed the text color and added some additional description.
Old 03-04-2013
My car won't start, any ideas ........................
Old 03-04-2013
Check battery, if battery is good and it just doesnt turn over, locate the starter under the car, obtain rubber mallet and give two-three solid strikes, try starting again. Still not starting? Locate fuel pump or fuel pump assembly on vehicle, check that power lines to fuel pump are securely fastened, if they are, shop around for another fuel pump. Note: lotta car manufacturers are thoughtful and place the fuel pump INSIDE the fuel tank
Still not starting?......Remove engine/transmission, strip all interior wiring and
accessories save steering wheel and brake pedal. Cut hole in floorboard and
YABBA DABBA DOOOOO!
Old 03-04-2013
my brain stopped working any ideas?
Punx223 said i was born this way...
Old 03-04-2013
As long as you weren't born yesterday
