Overclockaholics Forums » Cooling Performance Section » Water Cooling » Purchased a new/used water block.
Old 02-15-2013
ShrimpBrime's Avatar
ShrimpBrime ShrimpBrime is offline
ShrimpBrime is just getting started
Default Purchased a new/used water block.
I purchased a Swiftech GTZ block. It has s775 brackets I can use with my i7 3770K.
It looks really large on the bottom. How does this block fair for cooling?
Possibly used for TEC cooling cause of Witch_D getting my itch for that stuff going again. I can't stand it cause I can never find a decent way to run a TEC on a PC.... BUT never the less I really dig the challenges faced when using that type of cooling.
I'd just like to know about cleaning the block. From what I see there's a piece of plastic inside to direct waterflow. If this piece is removed, will it make the water block useless??
And the seal looks to be 2 piece? Should I purchase extras? Has there been known problems with this block leaking??
Thanks in advance!
Now running i7 3770K
AsRock Z77 Extreme 4
Antec 850w CP series
Mushkin PC-14900
Running DDR3-2200
Liquid cooled GTX 480
Old 02-15-2013
lol you just got this over at EOCF i got something from that guy also XD
you just need this $10 make you holla
Old 02-15-2013
The GTZs are good blocks, they were the standard up until a couple years ago. Think I got three of em in a drawer somewhere
Old 02-15-2013
I think i may still have one of them GTZ around the house somewhere lol
it's really based on which motherboard you are using it's different you may have a set of holes for 775 mounts.
Old 02-15-2013
http://www.swiftech.com/gtz-uhd-1156-bp.aspx
Old 02-15-2013
Yea at least the bracket isn't expensive . I also have the s775 hole drilled in the EXtreme 4 also which I'm using now.
Do you guys remove the hold down for the Cpu? I found the thing to be... well... big and bulky. 3 screws it comes right off?
Mushkin PC-14900
Running DDR3-2200
Old 02-15-2013
I woudln't cuz you don't want to bent any pins in the socket or you'll be well... SOL lol...
also DOMass, just don't.
Old 02-15-2013
Does that plastic bracket that the Cpu sits in comes off with the metal hold down bracket? So just bare pins out of the board?
Mushkin PC-14900
Running DDR3-2200
Old 02-15-2013
actually i am not 100% sure..
Old 02-15-2013
Lol! well if that little black casing stays there, I think it would be cool. But I need confirmation before I go tearing this thing apart again. I'm trying to make this one last a few months hehe....
Mushkin PC-14900
Running DDR3-2200
