Old 01-31-2013
Default New Grinder
Well anyone who follows this section knows my last build log was a bit to ambisious and turned out to be an epic fail ......... if you did miss and that is entirley possible here it is
http://www.overclockaholics.com/foru...ead.php?t=5226
FYI: I ended up assemeling that rig in a Bit Fenix Colossous, it is a way cool case but I have to say it was less than stellar. Anyway I have decided to go back to my roots and build something that I think anyway will be pretty effin cool.
This is going to be a long protracted build thinking it will go into the summer as some of the parts may not be availible until then. Or depending on what I am reading may decide to stay with SBE.
Anyway I will be starting this build by intergrating the cooling sytem into the case and inserting hardware as final specs become availible
Goal: To build something that looks great and kicks major ass AKA show and go, And practical of course ..........
Parts:
Case = Case Labs TH10
Motherboard = MSI X79A-GD65 (8D)
CPU = Intel 3930K
GPU's = 2x eVGA SC GTX Titans
Stix = Team Group 16GB PC3 19200/2400MHz 9-11-11-28 1T
PS's = Corsair AX 1200
Sound = Creative 3D Recon
HD 1 = 2x 830 Samies striped for OS
HD 2 = BFMD for storage and 2x 120GB OCZ Vertex 3 for games and programs
GPU Rads = 2x Coolgate Quad480's
CPU Rad = 2x Coolgate Quad480's
GPU Blocks = 2x EK-FC GeForce GTX Titan GPU Water Block - Acetal w/2x EK back plates
CPU Block = EK-Supremacy - Acetal - CSQ
GPU Res = EK-D5 XRES Top 140 CSQ w/250mm extension
CPU Res = EK-D5 XRES Top 140 CSQ
Pumps = 2x Multi speed D5 pumps
Intake Fans = Xigma XAF-F1254
Rad Fans = Corsiar SP120 Low Noise and Yates 38MM silent's
Fan Controller = 2x Lamptron FC5-V2
Fan Filters = Apevia FF-120BK
Some of the stuff came in today ........
Off to see the Wizzard ..........
Old 01-31-2013
More Pics
Old 01-31-2013
Reserved 2
Old 01-31-2013
looks great bud!
pretty excited for ya
Old 01-31-2013
Love watching these builds.
Reserved for comments
Old 01-31-2013
Will this be Crysis 3 ready ^^???
Old 02-01-2013
Hey WD, check out the Swiftech HD for your CPU water block. Great block IME
Old 02-01-2013
Doing research on them all ....................
Shame their are a couple missing, and lack of flow rate info basically makes this graph unusable.
The swiffy does well here for sure
Edit:
Case ariived today, pics added to OP
To summerize you simply can not imaging how big this beast is, Have sworn by Lian Li since 1999
Have had many and loved them. However there is a new kid in town and I am here to tell you.
While you could argue the Lian Li is a bit more vouge and elegant, They are mere toys compared to the professional level construction of the Case Labs product.
For you older gentelman it is Tim The Tool Man Taylor Approved ...........
completly modular put anything anywhere .... PS bay is large enough to house a single stage with room left over
Maybe next build ..........
Can house up to 32 Hard drives or 64 SSD's or any combonation of both. Any MB made will fit and will do 4x480 out of the box and 5x480 with bat adapter. I used an SSD to try to give it some scale
Old 02-01-2013
PhIlLy ChEeSe's Avatar
Love that case man, fawkin sweet!
Old 02-01-2013
You can use the stock water block that came with the Boreas if you want...not a nickles worth of difference between it and aftermarket if you ask me.
