Overclockaholics Forums » Hardware Section » Cases » I've been looking for a new case. This one has potential.
Old 01-04-2013
Default I've been looking for a new case. This one has potential.
http://www.guru3d.com/articles_pages...xb_review.html
99 bucks at New Egg
http://www.newegg.com/Product/Produc...82E16811119265
Old 01-04-2013
Wow, that is different
This is the one I like ATM if I were to build in a new case
http://www.newegg.com/Product/Produc...82E16811112367
Old 01-04-2013
Man that's a sweet case for a buck. Hovering over the buy button now.
Old 01-05-2013
Thats a nice case WD. Lian Li makes quality stuff. I have their HTPC case for my HT. http://www.newegg.com/Product/Produc...82E16811112228
but dayum, for $100 this case is sweet.
Old 01-05-2013
yea no doubt, have been reading up on it since this thread, I have mixed feelings on it. Looks tight, just the whole HAF design with the ridged corners and stuff , and can you get a push pull with a standard rad in the front, hard to tell with the pics.
Don't thnk it can pass as a tech bench as they state as it would be a bitch pouring into as the flask would hit the edges being 7.25" deep
a 200mm rad up top would be epic as well though and like the hotswap drive set up in front
If you grab it hope you do a build log to reaaly show what works and what doesn't with this new design, kida an old desk top case with a lower deck so to speak .......
Old 01-05-2013
I've been looking at the new HAF for awhile now, but the potential downside I see is that it says it fits mini, micro, and standard ATX mobos. None of mine fit any of those descriptions so I'd have to buy a new board too.
I'm kind of leaning towards this case to build a gamer for sale
http://www.newegg.com/Product/Produc...82E16811517020
Lots of air cooling and water cooling possibilities
Old 01-05-2013
Lil long in the tooth tho eh?
Old 01-05-2013
just have to wait for it to go on sale the mobo tray flips over to normal ATX and the side panels are interchangeable, so it's very versatile.
Old 01-05-2013
Bought an Azza once, It was a hunk of shit, can't speak to the linked one, but if their quality is the same across the line just say no, not to mention that thing prolly wieghs a ton, this is a decent buget gaming case with good build quality
http://www.newegg.com/Product/Produc...82E16811139009
Plus the one I linked above at 25% off is a steal for a full aluminum chassis
Although My next grinder build will be in Godzilla if it ever gets released
Old 01-06-2013
I've looked real closely at that one a couple times, thinking I want more fannage though cause I may not water the cards. Also, want it big cause it may house my X79
