Laptops On The Go...
Old 12-25-2012
Default Sony Vaio
Recently purchased this used Sony Vaio off ebay to replace the netbook for garage duties. The small screen of the netbook would often obscure many of the graphs I use for tuning of fuel injection tables and the 17" screen of the Vaio will be a welcome addition.
The new (to me) laptop is probably overkill for it's intended purpose, but for $200 I could see no wrong. It sports a C2D T7200 @ 2.00 GHz and 3 GB of memory. Came with Vista installed and seemed to work well without a hitch, but I really wanted XP for my uses. I made two recovery disc's of the original before beginning the XP install.
Several attempts of an install of Tiny XP were successful until it came time to boot from the hdd...it would then go to black screen. I had a legit copy of Vista 64 bit on hand and tried it with the same results. Even the recovery disks refused to cooperate. Finally I tried Tiny 7 which installed normally and booted right up and is currently running. Any idea's on what the problem might be? I still would rather be using XP.
