Old 11-27-2012
Default Godzilla
Water cooling Mecca
This text is copied, this will explain the proper englishg and spelling in below text ............
A leaked document from manufacturer Corsair has unveiled its latest full tower beast chassis – Corsair 900D Godzilla. In addition to the 900D, a mid-tower casing alongwith a AIO watercooling kit were leaked.
The Corsair 900D as the name suggests would be the successor to 800D casing supporting motherboard formats of ATX, E-ATX, XL-ATX all the way upto HP-ATX. The casing features a full chrome black color theme with a large side window and a mesh panel below it which can be equipped with fans to cool down either your radiator incase you use watercooling or pump out hot air from within the chassis.
The Chassis can support two two 480mm or two 360mm radiators simultaneously allowing top of the line watercooling performance for enthusiasts. Front panel includes headphone port, microphone port, four USB 3.0 ports, two USB 2.0 ports
Old 11-27-2012
WOW
Old 01-13-2013
http://www.youtube.com/watch?v=_0Q7x...0Tunw&index=52
Old 01-13-2013
Old 01-13-2013
Insane case, probably costs more than i spent on my pc though :(
I agree with george, no reason for an optical drive. I have thought about a bluray drive on and off, but figure now I will just wait for a redray player that can handle 4K or 8K resolutions.
Old 01-15-2013
Yea with the advent of the usb key I think opticals are pretty dead other than in HTPC build for the Blue ray capabilities, Loooking at the prices of the 4K displays at CES, I have to think I will be putting the redray on the back burner
Case is sick although for the cash you can get into a CaseLabs full alluminum chassis
