PSUs Lets Talk Power...
Old 03-18-2012
PhIlLy ChEeSe's Avatar
Default PSU PORNO
Well since I am the cheap type, you guessed! It's another PSU rebuild . I figured I repaired one already, plus I may be able to debtor things from happening down the road. As an added bonus I gonna link you guys to one of the coolest sites on the internet(@@badcaps.dom****))). Here's a link to the PSU repair that I did before, my first one(BFG/GR650WGSPSU).
http://www.badcaps.net/forum/showthread.php?t=15841
They also helped me fix an LCD display linked it, this was a CCCFL replace in the end
http://www.badcaps.net/forum/showthread.php?t=16193
And they helped to fix my 42 Insignia LCD TV, I replaced the PSU TV back working......... So here we go roll up your sleeves and don't be afraid
This is a 1000Kilowatt EnerMax Galaxy PSU, and we already know that it has a faulty 5v(red wire) Rail that is killing everything.
A little work history of mine, I used to do remote starter and alarms, high end systems, theft recovery's (the S10 steering column rebuild, new ignitions). I did this for 12 years from the time I was thirty. Since that time I do electronics repair more or less for the last six years.
Old 03-18-2012
Old 03-18-2012
nice hope you can fix it
I got an lcd screen that would start to blink when started up but then would stop blinking and work normally.... But now it just stooped working could that be some thing that could be fixed ?
Old 03-18-2012
Yup sounds like its the inverter board that plugs into the CCFL, hold a flash lite up the the screen while the monitor/computer is turned on see if you see the desk top?
Old 03-18-2012
nice. I had a galaxy 850W back in the day, pricey stuff.
Old 03-18-2012
I got the 850 in my e mailer got it new off flee bay cheap, they have a good RMA think they fixed the 1KW one about three time's. They didn't care the sticker was missing off the screws, I told um it was so I could clean the unit out. There a pretty cool company!
Old 03-18-2012
Kool Stuff
Old 03-19-2012
We know its a weak five volt rail, plus I'D like to beef it up a little bit so as not to worry about hooking my stuff up to it again. I'll be linking this thread into badcaps soon to get there advice, all they need is clear pictures of the top and the bottom on the main board. They like high resolution pictures as it helps them to see any issues.
http://www.badcaps.net/forum/showthr...244#post225244
LOL<
Well so far one guy over there has kinda trouble shoot my issue and offered to buy it off me for a few bucks...............WTF! Anyone here know about DC-DC converters? All you got to do is point me in the right direction and I can use a multimeter to test it.
Old 03-24-2012
Well I think we pretty much have the issue pined down to aging caps on the secondary side of the PSU, (secondary side) being the lower voltage output side. I have ordered new caps for it, funny thing is EnerMax makes a good PSU! BUT on my PSU the primary side has RubyCon caps witch are high quality caps with a long life n lower ESR. On the secondary side they put cheap caps, witch are not quality and do not have a long life. All my parts cost about $15.00 as I broke a transistor while trying to read the spec's off of one of the caps that were under the heat sink, they are all quality caps i purchased with long life and low ESR ratting. We will then load test the PSU(with stuff I don't mind losing) to see how the 5v rail is doing and proceed from there.........
I ordered my stuff from DigiKEy witch is about the cheapest and has everything you may need when doing caps, these are also used for modding.
http://www.digikey.com/?gclid=COmL2p...7d72csP18y0qzD
Old 03-24-2012
Good info, thx PhiL
