Old 02-10-2012
Question What if ... a new use for an SS
Started thinking today, which is always dangerous, and hit upon an idea that may or may not work. Depending water flow I think.
What if instead of a radiator, you hooked a CPU water block up to the head of an SS and used that to cool the GPU loop? In this case, the thought occurred to me regarding chilling the water for my quad sli 580s. The Feser quad does a good job, and I have a DYI chiller unit, but since I have a spare SS and CPU water block, my mind wandered into this idea.
Would it work so long as the water flow was maintained? I think so, but I'm thinking I might be SOL if the rig needs to reboot too often while tuning the OC.
huh??
Old 02-10-2012
I'm guessing the coolant would freeze in the block before leaving and stop the flow.
Old 02-10-2012
you would have to introduce a glycol solution / AKA antifreeze
take the rads out of the loop
I woould also keep the flow as slow as possiple to maximixe heat transfere at the block, but yes it would work under those circumstances ........
you will probably create condinsation so insulating the cards would not be a bad idea
but it depends on what type of heat transfer you get across the block and flow will determin
I would have to think with a 20 run time you could drop the loop temp considerably
it may have to catch up between benches as 4 of those will put off some heeat
Old 02-11-2012
I don't think there would be enough surface area on a water block to keep the loop cold. i guess that would depend on the lenght of the loop. You could always try it and let us know.
Old 02-11-2012
I think WD is right, and disassembling and erasering the cards isn't something I think I want to spend time on right now. The heat of the 4 gpus should keep a glycol solution mostly liquid but I had been thinking water like Supes. Surface area is another good concern.
oh well, back to the drawing board
Old 02-11-2012
Kmart
32 quart cooler
Add 4/120 radiator ....... insert 30 lbs. of ice on top of it
turn on system and comence benching FTW .............
Old 02-11-2012
Kmart
32 quart cooler
I have one of those big beer chest coolers with a collapsable handle in which I've wound 50ft of 1/2 copper tubing connected to a 300gph fish tank pump, with a little resv to fill and monitor it. It's hooked to about 10ft of hose on each side. Fits 60lbs of wet ice. I've used it before to great effect, I think my VRs were down in the 7C range and the GPUs were about 14C. May break that out again but again condensation is a worry
Old 02-11-2012
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
Gets too thick that cold. Windshield juice.
Old 02-11-2012
Great idea, didn'6t even think of that .............
Old 02-11-2012
With the wet ice chiller water works cause you never get below freezing
