Overclockaholics Forums » Hardware Section » Motherboards » Intel » MIVE P67 Error Code Help
Old 01-03-2012
Default MIVE P67 Error Code Help
Anybody know WTF is going on with 06 debug
keep getting it, book says microcode loading ???
it just hangs there. reset BIOS no help used 2nd BIOS with the same result
Any one know how to fix this or is the board wasted
Old 01-03-2012
Don't remember having probs with 06 Bro - I had issues with 19 and 25 which eventually resolved itself. Reboot a few times at default settings and see if yours resolves itself too..
good luck
Old 01-03-2012
been down that road working on about 30 tries on both BIOS chips
It just blows man ........ can\t swing a new board right now spent all cash on those Lightnings
Anyone else have any ideas
Old 01-03-2012
06? do any of the side led's light up?
Old 01-03-2012
yes they do . looks like it will boot then once it gets to 06 it just hangs there ???
Old 01-03-2012
Gutterz's Avatar
Gutterz Gutterz is offline
did you pull the battery an all that jazz? Also try differant ram slots with 1 stick, maybe reseat the cpu. Im not sure just suggestions.
Old 01-03-2012
yea pulled the battery and stix .......
did not try reseating the CPU though, I will give it a try
wierd though as it happened when switching vid card ... took the 580 out and put the 6970 in and bang there was the error
put the 580 back in and error is still there
I know the 6970 to be good as I was doing some testing on it a few weeks ago
Old 01-03-2012
As Splave explained to me when I was having my error code problems, the MIVE seems to have a tuff time dealing with system changes despite what you do in BIOS.
My error code problem literally disappeared after a few tries.. was really wierd... man
Old 01-04-2012
HybridChiller's Avatar
i got the 06 also on M4E once, when my 8750 lightning was dead.
All led's and fan of vga runs but mobo hangs on 06.
Vga was dead with me, maybe test vga in another rig?
Old 01-04-2012
Thanks, I will give that a try, but have tryied 4 different cards in the mive that were good cards previously
man if all these cards are bad that is worse than the MIVE being dead
