Overclockaholics Forums » Hardware Section » GPUs » General GPU » GPUs In Parralel or in Series (watercooling)
Old 11-22-2011
Default GPUs In Parralel or in Series (watercooling)
I have always plumbed my tri-sli's to be in series, same with SLI setups. According to Switech, plumbing them inparralel is supposed to result in less pressure drop with no loss of cooling. It seems counterintuitive to me.
Any thoughts?
Old 11-22-2011
is it maybe because they sell a special part to do this?
Old 11-22-2011
They have a new CPU cooler with 1 inlet and 3 outlets so you're supposed to run everything in paralel.
Main reason for asking is my 580 waterblcoks are Auqugrafix and they have the funky connectors. You can't really use 3 x 1 connectors very easily if at all, so I bought the connector for tri sli which is made for quad sli
It can be configured for either paralel or series but doing it in series like I prefer is a real PITA. Apparently parallet works, but Guess it works along the same principal as heat pipes??
Old 11-22-2011
They are right,
Parallel is the best way to maintain volume and temprature.
I pipe my commercial water heaters and chillers this way.
You just have to remeber that the header has to have eaqual lengths and fittings to maintian an even flow through out the manifold, if not one end or the other could suffer.
Theiry is that all blocks are getting the same temp as the manifold as opposed to one then the second getting the first cards gain and the third recieving the first and second cards gain. This is absolutly manditory for chiller and domestic water heating and many times when not done properly it is disasterous
Example:
When at a hotel 6 the hot water for your shower is weird, real hot then cold then hot again
When done right hanging at the Hyatt Regency your shower is solid as a rock with this proceedure being executed properly
Parallel = WIN for a multi card set up
Old 11-22-2011
HybridChiller's Avatar
when you use a good pump, is better to use in parallel, so every vga get's the same cooling, in serie you will get more resistance in loop of all the vga blocks behind eachother, and temp will be different between then, even when it's small difference.
When you use a triple sli cooling bidge, it's in parallel.
A cpu block need some more flow then a vga block.
When you put vga's in series, the flow can be to slow for cpu block and in that way temp will be not so good on cpu.
Old 11-22-2011
I set it up in parallel and the second card ran 1 to 2 C warmer than the 1st and 3rd
Old 11-22-2011
not bad
With a better pump u may be able to get it on the money
Old 11-22-2011
not bad
jeez dude, got a Laing D5 turned all the way up
Old 11-22-2011
Old 11-23-2011
I have an eheim 1260 that pumps 900 gal an hour. Problem is it has a 1inch intake and a 1/2 output Never supposed to throttle down the intake
Besides, it wouldn't fit in my dual bay pump/resv combonations :
