Old 11-16-2011
Talking "New" 2600k plus Repaired SS
Still room to grow on both the CPU and GPU, plus - have to see what this chip will do under severe cold with the lightning bolted on Sorry about the pic quality
I left speedstep on rather tahn using ROG Connect, then used Evga OC to bring the clocks up for the pic
Tomorrow 2 or 3 GPU's and prep work on the GORGEOUS R4E
Have posted two of these on the bot for a whopping 7 boints Hey.. it's a start :
ID:	5891   Click image for larger version
ID:	5892   Click image for larger version
ID:	5893   Click image for larger version
Old 11-16-2011
Grats bro, good to see you benching..............
Freeze dem bastards
Old 11-16-2011
Freeze dem bastards
hey Bro - your SS repair is AWESOME!! Never got warmer than -41C
thanks again
Old 11-16-2011
Awesome MD. 01 score looks low though (way high for me, but I suck at 3D lol)
(Oh just noticed you didnt tweak the test just ran it all default hah hah even ran extra ones )
Old 11-16-2011
Inspector Detector
there was a post that a tweak in their other than lod .... can't find it to save my life though ???
Hope it holds up well for you Daawg .............
wonder how it will do with the six pack, may have to strap a pot on those bastards
good luck with your chip, binning SB-E looks budget crippling
Old 11-16-2011
Yeah WD, at a grand a pop I ain't gonna be buying very many of those Couldn't afford the one I got :
Old 11-16-2011
So why does your 05 say the CPU is on air lol
And you should be able to see how high the CPU clocks on the ss
Old 11-17-2011
nice! didnt take you too long huh
grab the 01 bios and flash it to your backup bios chip. then enable extreme tweaker option in bios. Should gain you about 3-4k
Old 11-17-2011
DOM, i did the 05 the day before and it was on air. The clocks didn't show correctly because I had speedstep on so I could increase the core speed in the OS using TurboV. Hadn't though of running the Evga OC CPU burner to bring the clocks to the full speed until last night
01 it is boss
Old 11-17-2011
yeah, I forgot to turn off the effing extra tests... pissed me off
