Overclockaholics Forums » Overclocking Section » Overclocking » Aquamark - Problems in score
Overclocking Air & Water...
Old 11-15-2011
CjBA's Avatar
CjBA CjBA is offline
CjBA is just getting started
Default Aquamark - Problems in score
Hi, it's a pleasure participate of Overclockholics forum
I need help, my score on aquamark is low...
In Windows XP 32bits+ForceWare 169.21+7300SE(Core/800\Memory/800)+2500k@4,7GHz my result is 2k for GFX and 30k for CPU, in Windows 7 64bits+ForceWare 260.99+7300SE@675(Core/800\Memory/800)+2500k@4,7GHz is 9k for GFX and 2k for CPU.
I would like to know if you like someone to help me achieve good results in the CPU and GFX?
Sorry for the English, i am from Brazil....
Thanks for the attention!
Core i5 2500K - Corsair H60 - AsRock P67 Fatal1ty Professional - 3x2GB Kingston HyperX 2000 C8 - PNY 7300SE/ZOTAC 9500GT/ZOTAC GTX460 1GB - CM Storm Scout - Enermax Revolution 85+ 850W - Raid0 Corsair Force II 60gb+Samsung 500GB
Old 11-15-2011
HybridChiller's Avatar
you need the patch and DLL, and you should get some points.
Reminds me that i need to do that 7300se series also on Hwbot
Old 11-16-2011
He must already have the patch and the DLL if he's running it in Win7 64bit ?
I'm no aquamark expert though
How much system RAM are you running?
Old 11-16-2011
You don't have all the cores enabled in task manager on you CPU. For the life of me I could never get all cores enabled in any OS except XP.
Old 11-16-2011
I just enabled all cores, but IIRC if you rename it it works too?
Old 11-16-2011
CjBA's Avatar
Hi...managed to solve the problem, I was with the patch, however it did not work, I downloaded again and it worked
4Gb(2x2gb) Kingston HyperX Elpida MGH-E@1866 7-7-7-12 1T
Tanks!
