Overclockaholics Forums » Overclocking Section » Extreme Overclocking » Problem in setting the 12G Dominator CMG6GX3M3A2000C8 to 2000mHZ
Old 10-21-2011
Evilz Evilz is offline
Evilz is just getting started
Unhappy Problem in setting the 12G Dominator CMG6GX3M3A2000C8 to 2000mHZ
Hi everyone,
Using the ET6 i manage to OC my CPU easily at 4.16GHz, but with the ram at 1600mHz only.
Can anyone help me to crack this problem, as im a newbie to OC...........
Intel Core i7 975 Extreme Edition 3.3GHz|Cooler Master V10 processor cooler|Gigabytes GA-X58A-UD7|Cosair Dominator GT 12GB DDR3-1333 8-8-8-24|PowerColor 5970 2GB|Creative X-Fi Titanium-Fatal1ty|Seagate Barracuda XT 2TBx2|Thermaltake Tough Power series 1500W|Coolermaster Cosmo S 1000|
Old 10-21-2011
HybridChiller's Avatar
set the memory manual in bios, also the timings and RAM voltage to 1.66v.
Take a divider of mem, that you're mem comes around 2000Mhz or just a little less.
that should work. ET6 sucks big time
Old 10-21-2011
Ditto
Old 10-22-2011
Might need to really boost VTT to get all 12GB running at 2000 MHz
Also not all CPUs will be capable of pushing that fast with that many slots filled
EDIT: Also the 975E defaults to 6.4GT QPI speed, when bus clocking that gets pushed up, few cpus can handle going much past 8 GTs
This also will require more VTT/IOH core among others (little rusty on X58 )
