Overclockaholics Forums » Hardware Section » GPUs » ATI » Build your own EVbot for AMD cards
Old 10-20-2011
Default Build your own EVbot for AMD cards
Requires a couple bucks in a parts and some software to get it running, so not exactly the same but neat nonetheless
http://forums.hackaday.com/viewtopic.php?f=3&t=1072
Old 10-20-2011
HybridChiller's Avatar
you can use a EVbot for a ATI 5870 if you whant, all vga's that have Volterra VRM
this is where you connect of the 5870
here is the map for the evbot connector
now only one out of the 4 connections to the evbot seems to need +5v, +3.3v and gnd (please correct me if im wrong mate), so if your using a classified board then you can connect that to your evbot and the other 3 gfx cards dont need power...
with just 2 wires he takes your 5870 VCCD and Vxxx?? to 2.0v if needed
