Old 09-15-2011
lesstutrey's Avatar
lesstutrey lesstutrey is offline
lesstutrey is just getting started
Default Prefered solder
Anyone who does voltmodding have any preference in solder, or do you just pick up stuff at radioshack? I'm having troubles getting small beads. (and i have a nice hakko 936-12 station and a few tips that i cannot get a small bead with. Dunno what heat to set it at either, seem to go too high if anything.
Old 09-15-2011
I use RadioShack .015"-Diameter 62/36/2 Silver-Bearing Solder + a $5 Walmart soldering iron and it works Grrrrrrreat!
Old 09-15-2011
lesstutrey's Avatar
i've probably been using to heavy gauge of solder to get the bead small enough. I shall head to the shack tomorrow.
Old 09-16-2011
Are you tinning the tip of the iron first?
Old 09-16-2011
Tru dat. I always tin my tip and my wire or VR legs, etc.. I usually don't even need to use solder when the connection is made.
Old 09-16-2011
lesstutrey's Avatar
i think i am..by tinning you mean preping the tip with a small amount of solder on both sides right? perhaps i'm getting too thick a coat then so i get too thick a bead?
