Old 07-03-2011
HybridChiller's Avatar
Default Some new toys in the house
Hi Guys,
i have some new toys in the house.
A custom build phase-changer that can hold to -43°C with more load then a normal one.
And a modded Prom Mach 2Gt that can go to -50°C.
also a TEK9 6SLIM pot and a F1EE with extension kit is in.
Today played already with some old lga775 cpu's that where dusting away in the closet.
http://hwbot.org/user/hybridchiller/
New submission are visible on profile page down below with the Pentium 4 517 highest clock 5040Mhz.
Still got some 13 lga775 cpu's and S478 cpu's to,
2x 8800GTX, 8800Ultra, GTX580.
And looking for a good Sandy bridge cpu that does 5.6 and more
Next days will have fun enough with benching them all under Phase-change.
Old 07-03-2011
SChweeet dude. You'll have fun i'm sure.
Old 07-03-2011
Congrats on your new toys
Level !! Noice!
Old 07-03-2011
http://valid.canardpc.com/show_oc.php?id=1892588
Old 07-03-2011
http://valid.canardpc.com/show_oc.php?id=1891499
Now playing with P4 D 955 EE, and i think this is a nice onhe for under ln˛ on a Rex X48.
Let's go searching for a good REx X48 and a Asus Commando.
Here i'm limited to Vcore max of 1.7 and temp sub-zero, this cpu can do more for shure :
http://valid.canardpc.com/show_oc.php?id=1892714
Old 07-03-2011
Just vmod the mobo 1st and see what she will do. Might save a buck or two and cure your 1.7v max in the end. Had the same dilemma with my P5B Deluxe.
Old 07-03-2011
holy shit bro! you got some nice ass bench ahead of you bro!
LN2 overclocking is like a drug if you had it once you realized the fun in it you just wanna keep on doing it over and over
Old 07-03-2011
is taht a Thermaltake Grand PSU?
If so how do you like it? and hows it work when benching?
Old 07-03-2011
Don't find a Vmod guide on the net for the Asus P5w dh deluxe mobo
P5b deluxe can go to 2v Vcore i believe ?
i did ln˛ before but the thing is here it's very expensive.
That's why i always did dice, that's very cheap here.
yes a Grand 850W, the rig it powers is light, doesn't take so much, but i didn't test it yet with a heavy vga for benching, untill now it holds nicely the 12v rail steady.
Old 07-04-2011
Nah, the P5B Deluxe does 1.7 max too. With vmod I can crank out around 1.95v. I am positive yours will be the same. Here are the mods for you.
