Overclockaholics Forums » Cooling Performance Section » DICE & LN2 Cooling » How to: Bench MSI Lightning GTX-580 for dummies
Old 06-09-2011
Default How to: Bench MSI Lightning GTX-580 for dummies
Everyone has their own way to do things but this is what has worked for me. This is how I bench heaven...
1.Cool to -50c idle in windows
2.Glaze your pot
3.Start benching at stock speed and volts except memory bump +175v ish
4.Slowly cool down pot while benching to -135c (if you hear a loud crack start over and heat back up to -50c.)
5.While at -135c you can set temps and volts while idling in OS 1450/1400 = +449mv Core +200mv Mem +000mv AUX
6.Pull down pot to -150c and start bench..you want to hit -160c by end of loading screen.
7.Slowly pull down to -180c during the first 2 or 3 subtest in heaven and just splash the pot enough to keep it there, do not fill up the pot (thats when I get cracking I believe)
8.Lighten up on your pouring for Test 25-26, let it warm back up to -170c by the end of 26.
9.Once the test is finished do not do anything until you pull back up to -140c or you will freeze when opening GPUZ (you want to be back around -140c anyway so you can apply clocks again for your next run)
***Dont apply clocks with temps colder then -145c***
***Dont Open GPUZ with temps colder then -145c***
-Device lost error = more vGPU or more Cold
-Test 20 freezing = more vGPU
-TIM is very important
-No secrets/
Its seems a function of OCP is occuring at 1470/1400, causes voltage to drop to 0.300vGPU and will stay that way till power is cut at PSU.
Hope this helps
Old 06-09-2011
Very nice run down there.
Old 06-09-2011
Mafio's Avatar
Mafio Mafio is offline
Mafio is just getting started
nice writeup, thanks for sharing
Old 06-09-2011
wish i had a 580 in hand right now :(
Old 06-09-2011
Hey Bro -
Thanks for the tips and pics. As soon as I finish the BEAST review I'm gonna start putting this info to use
Printing as I type
Dude, dumb ass question here - are these temps the CPU or GPU ???
hey, at least this time you didn't call me a stubborn geezer :
Old 06-09-2011
Hope this helps
It sure does, thanks
Old 06-09-2011
Nice bro!!!
Old 06-09-2011
Nice bro!!!
Old 06-09-2011
Awesome share Splave, that insulation job looks exquisite though not as much as Vivi,
I thought its of the Monitor, thats what displays GPUz and clocks right???
Old 06-10-2011
thanks guys! maadd this is only talking about GPU
