Old 05-29-2011
Default Zotac 280 AMP mods?
Anybody have linkies to hard/soft mods or BIOS recs?
Asking up front because I've been known to spend a week making a frankencard, only to find out later that some random BIOS tweak eliminates OCP or some such thing......
Old 05-29-2011
reflex99's Avatar
reflex99 reflex99 is offline
reflex99 is just getting started
something about that last sentence made me almost blow sprite out my nose
My Hwbot<- i try
current gear:
Phenom II/TA890FXE -Bench stuffs
Old 05-31-2011
pretty sure the amp is still of reference design
"Being a copy of the reference card, the Zotac has a seven-phase power circuit governed by a popular Volterra VT1165MF controller. One 6-pin and one 8-pin connectors are used for external power supply."
http://www.xbitlabs.com/articles/gra...x280amp_3.html
But I think you can breach any OVP from using software to up volts, like on the lightning 275
Old 01-22-2013
Anyone use the 280 gtx VDD and/or the VDDQ mods for this card or the stock 280s? Not sure what they are or what they control, any insight would be helpful.
