Overclockaholics Forums » Hardware Section » Monitors » need help!!! am confused :(
Monitors If It Is A Display...
Old 05-23-2011
sumonpathak's Avatar
sumonpathak sumonpathak is offline
sumonpathak is just getting started
Default need help!!! am confused :(
Hi guys!
need an new display....but am a bit confused about what size to get?
so here goes my NOOB question : what is the minimum size i have to get to run benches and normal day to day work @ 1280*1024.....i think thats the highest i need to run 3d vantage and 3dmark 11.....if i am wrong then plz correct me....
help out a brother here....
cheers!
Old 05-23-2011
Nearly any lcd monitor you buy these days will suffice for your needs.
Not the best, but not bad...http://www.newegg.com/Product/Produc...82E16824236059
Old 05-23-2011
Yea I have heard the Asus monitor are pretty decent, I use a 24" Asus at work and works nice .....
Personally I like to have a 1920 x 1200 so I can compete in the top res X3 thread .....
Old 05-23-2011
dont think am gonna find it here....so the lowest i need is an 22 incher?
good luck with that
any other suggestion guys?
gonna get one in two days
Old 05-23-2011
It isnt the physical size of the monitor that matters, rather the resolution it supports.
Old 05-23-2011
thats where am confused :(
which size supports which and what not *bangs head*
Old 05-23-2011
Just decide what the max resolution you can live with and shop the spec's when looking for a monitor.
Old 05-25-2011
got this
http://70.32.73.36/monitor_display/e2243fw
Old 05-25-2011
That should do nicely.
Old 05-29-2011
Bones's Avatar
Bones Bones is offline
Bones is just getting started
For the record, I had to replace my old Viewsonic G800 21' CRT last March and got one of these:
http://www.newegg.com/Product/Produc...82E16824236117
No dead or stuck pixels so far and it looks really good. Virtually no lag that I've been able to see in games so far and the monitor has a variety of inputs you can use; DVI, VGA and HDMI so whatever card you might have should work with it. Plenty of menu options too and that's a plus.
Of course I'm NOT using the built in speakers - Not that desperate (Yet).
As for gaming, to me it's the perfect size, not so big you can't see everything within your field of vision yet big enough that you can see everything right down to the smallest details.
For under $200.00 it's a good deal.
