Overclockaholics Forums » Cooling Performance Section » Water Cooling » TEC Setup Help/Needing Ideas
Old 05-05-2011
Question TEC Setup Help/Needing Ideas
i been doing alotta thinking and i wanna go back to 775 one more time here is what i got right now...
Intel SLAWE Q9300 M1 - new never overclocked
2x2GB DDR2 - never clocked either but i know it ain't gonna go anywhere
Swiftech MCP 655
Swiftech 3x120
D-tech 775 waterblock <- this is old
thinking about clocking this chip somewhere around 1600mhz in FSB that makes 3000~3500mhz i'd like to 4+ but that's only if it's got good cooling and great ddr2 or ddr3
just quick question...
will it be better if i just drop some extra cash and go ddr3 so there is a passable way to get higher clock if i wanna
i think i have 2 peltiers and should i hook that up to like a different PSU or just leave it on the same one i think it's like 65 or 68w peltier or should i just get a different peltier and hook it up to a different PSU cuz i do remember last time i was doing this sometimes the peltier don't start up right away or kick in at all! kinda sux!
so what do you guys think?
looking for a motherboard right now... but needing something that's gonna take at least 6 SATA HDDs /i may not even have a dvdrom in it just because i never use it!
Old 05-05-2011
I wouldnt share a psu between the system and peltier. Seperate is better.
Old 05-05-2011
You want this for a 24/7 setup???? See those P4's were not power efficient at all, so until you wanna go for records there is nothing beneficial that you will get from the platform.
Old 05-05-2011
yeah you guys are right ...
i think i monna just run it with water and be done with it or hell just run it on air...
and when i wanna go clock i'd put it under dice or ln2 right?
i been looking at the bot and some how no one has put this chip under LN2 or dice and DID GOOD! what's up with that
the highest is 4.1ish and that's on COLD air
will it be better with ddr3 or ddr2 if i go for the high clocks?
