Overclockaholics Forums » Hardware Section » Motherboards » Intel » I bent some pins....
Old 04-18-2011
ny_driver's Avatar
Default I bent some pins....
I fixed them I think as good as I can using high magnification and it looks like they would all make contact with their respective pads......but it wont post. I get D4 on the LED readout.
I guess I'm keeping the board now. I wonder what it would cost to get the socket replaced?
(the glass on the inside of my scanner needs cleaning I think.)
The bent pins were in the top left corner.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 04-18-2011
GeorgeStorm's Avatar
I can't see any bent pins?
Looks like a pretty darn good job you've done, no idea why it's still falling over :/
RMA it?
Old 04-18-2011
ny_driver's Avatar
now I get code FF on th LED readout. Pins look perfect.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 04-18-2011
ny_driver's Avatar
Back to code D4
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 04-18-2011
Mr.Scott's Avatar
Mr.Scott Mr.Scott is offline
FF means attempting to boot to OS. There's nothing wrong with the hardware.
Old 04-18-2011
ny_driver's Avatar
There were some bent pins in the socket. After about 10 repair attempts I finally got it good enough.
She's running now!!
Man that was some seriously delicate surgery to repair/rebend some of those pins.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 04-18-2011
Don't feel bad...I pulled a pin clean out of my 1090T removing a pot some time ago. No chance of rma for that lol.
Old 04-19-2011
ny_driver's Avatar
Did the pin just break off or did it actually pull out like you said? If the pin pulled out of the chip I'd be trying to RMA. If not I'd be trying like hell to solder a pin on there...........if the chip doesn't work minus 1 pin. I had one 939 that worked with only 938 pins.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 04-19-2011
i did one time where the pin broke off the 478 chip and what i did just just put the pin where it should of been and just lay the cpu on there then just let it all falls in at the same time and it worked like that lol
ny you ran it with 938 pin prob cuz that one pin didn't realyl do much in the chip it self
Old 04-19-2011
ny_driver's Avatar
Wow it's only $35 to get the socket replaced, plus shipping I'm sure......but still that's way cheap.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
