Overclockaholics Forums » Overclocking Section » Overclocking » Sandy noob need P67 UD4 OC help guys
Overclocking Air & Water...
Old 04-15-2011
Default Sandy noob need P67 UD4 OC help guys
Brand spanking new to sandy and looking for some tips and links to overclocking on gigabyte.
Up to 4.6ghz atm with everything on auto but cpu is downclocking.....
Should i be bios clocking mostly or software?
Using a 2600k.
Old 04-15-2011
i use the bios and soft for raising the blck
i use auto on most and just set vcore and mem volts
Old 04-15-2011
I just press lots of buttons really fast and hope something eventually works
Old 04-15-2011
@ DOM are you keep load-line cal on auto?
@OC button mashing ftw haha
Any thoughts to what kind of voltage gap SB like for 5ghz? Also what is the danger zone for voltage on these guys....
Old 04-15-2011
Depends on cooling.
Old 04-15-2011
W/Cing temp controlled chiller set to 22C
Old 04-15-2011
LLC 1
new f3 bios just had lvl 1-10 i used 5 on that one
also i was on ss
but on water i still got x55 multi
so check the max multi first see wut kind of chip you got
Old 04-15-2011
do the new bios allow for bios template saving be chance....
Old 04-15-2011
5.4 = 1.64 on mine using an H70
multi clocking
LLC 100%
vtt 1.25-1.5
PLL overvolt
mem what ever you need to get the timings you want I use 1.75 for 6-9-6-26 1T on my ripjaws
all the CPU garbage off
Max power power settings
tubo on
bclk is very limited ...
then you stick any old card in the slot and it starts raining boints
Old 04-15-2011
Thanks guys first night with it.
WD i'll try those in morning and post back results of my chip
