Overclockaholics Forums » Overclocking Section » Overclocking » In Need For Help i7 970 + Dice
Overclocking Air & Water...
Old 04-13-2011
Default In Need For Help i7 970 + Dice
for some strange lords knows why but like i can't seems to clock anything higher than 220 on this chip, it's like it'll boot but not gonna beable to get any higher than where it's at right now...
i am on dice right now and what's really funny is that when i was on LN2 the best i ever got out of it was 225 im so
i know this is a really good chip and i should beable to do 230~240 if not any higher
and i don't know what did i do but Turbo mode never kicks on anymore... even if i reset the biso
Extreme Cooling [Mode 2]
CPU Clock Ratio [ 24x ]
CPU Host Frequency [ 220 ]
MCH Strap [ AUTO ]
CPU Uncore Frequency [Mhz] [ AUTO ]
CPU Clock Skew [ 0 ps ]
Spread Spectrum [ Disabled ]
PCIE Frequency [Mhz] [ 109 ] -> [ 112 ]
EVGA VDroop Control [ Without VDroop ]
CPU VCore [ 1.59 ~1.62 ] -> * Lowering the vcore
CPU VTT Voltage [ +300 ]
CPU PLL VCore [ 2.025 ]
IOH PLL VCore [ AUTO ]
QPI PLL VCore [ 1.3 ]
DIMM Voltage [ 1.65 ]
DIMM DQ Vref [ +0mV ]
QPI PLL VCore [ 1.300 ]
IOH/ICH I/O Voltage [ 1.600 ]
IOH VCore [ 1.300] -> [ 1.200 ]
NF200 Voltage [ AUTO ]
VTT PWM Frequency [ 610 KHZ ]
CPU PWM Frequency [ 1333 KHZ ]
CPU Impedance [ Less ]
ICH VCore [ 1.10 ] -> [ 1.25 ]
DDR Signal 0 [ +0 ]
DDR Signal 1 [ +0 ]
DDR Signal 2 [ +0 ]
CPU Signal [ +0 ]
QPI cpu [-40]
QPI pci0 [-60]
QPI Signal 1 [ +0 ]
QPI Signal 2 [ +0 ]
QPI pci1 [-31]
QPI pci2 [-31]
Intel SpeedStep [ Disabled ]
Turbo Mode Function [ Disabled ] <- no matter what i do here the Turbo don't kick on
CxE Function [ Disabled ]
Execute Disable Bit [ Enable ]
Virtualization Technology [ Disabled ]
Intel HT Technology [ Enabled ]
Active Processor Cores [ All ]
QPI Control Settings [ Enabled ]
QPI Link Fast Mode [ Enabled ]
QPI Frequency Selection [ 4.800 GT/s ]
Old 04-13-2011
PCIE freq to 110+
you will probably have to raise ICH and IOH vcores though. 1.3 IOH might get you there... at 110 PCIE though 1.2 easy on ich. make sure it stays cool too easy to overlook overheating southbridge
Oh and try an odd multi. (heard it, never had a CPU that had an even multi so... never tried it to see )
QPI PLL helps... TBH I do not remember if 1.3 was enough, since it has been so long and last few boards I had did not have that. It defintely helped on earlier boards though... Foxconn (IOH Vcca 1.1) and EVGa.. (qpi pll).
Old 04-13-2011
thank you so much sorry i started bleed again i monna try that when i get home from class tomorrow
Old 04-13-2011
I just realized you were using 109 pcie freq. not sure what board you are but if it is the e758... you wont get past 222.
Old 04-13-2011
Spank's Avatar
Spank Spank is offline
Junior Addict
Spank is just getting started
hmmm increasing PCIE Frequency is doing any good at all at performance of overclock ?
Intel Core i7 975 Extreme Edition 4.3GHz 1.375vcore|Asus Rampage 2 Extreme|Corsair Vengeance LP 12GB DDR3-1600|Asus GTX570|Creative X-Fi Titanium-Fatal1ty|Intel Postville 80GB SSD,300 GB WD Velociraptor,2X640GB WD|Silverstone Strider 1500W|Samsung Syncmaster P2370|Coolermaster Cosmos 1000|Razer Lachesis Precision 3G Laser|SteelSeries 5H v2|
Old 04-14-2011
i monna do that when i get home from class today..
thanks guys i'll keep y'all updated
Old 04-14-2011
If it is the 758 I sent it did 229 with a 920
Think pcie was 112
Old 04-14-2011
On my e762 I use pcie of 112 and get up to 240.
Old 04-14-2011
sweet! 112 it is then!
do i have to change any other voltage?
Old 04-14-2011
lower vcore is for sure. I maxed out at 227 on my e758.
http://hwbot.org/community/submissio...min_4sec_840ms
