Old 04-07-2011
Default New WC Gamer
Quite possibly a more challenging build than even the BattleStar
Built in a Corsair 800D with 2 loops and 3 rads I'm thinking I pulled it off rather nicely and that it looks pretty sharp. Unfortuanately I'm gonna have to tear it down and rebuild it before I can use it due to a glitch in the motherboards matrix .
Built on a Classified 769 ( the 760 with the HC chipset block and an EPC, a 980X and a EVGA GTX 590, this should be a screamer once I square off the mobo issue. For some reason it hangs at 25 on every cold boot, but if you hit the reset it boots right into Windows no probs You can't see it but I mounted a Kryos HT (not sure of the initials) to the CPU (its a big ass chuck of copper through and through) using a Kingpin mounting system cause the one they sell you doesn't work.
Feser Mosta Lite 3x140mm RAD running horizonal on top cools the 590, the EK 2x120 and the Thermochill 1x120 cool the CPU and chipset. Beast is quiet but deadly :
Took a couple pics, as you'll see I used quite a few bitspower snackes, curves, extensions, yada, yada, yada to replace tubing in many places.
I'll post full pics when it's officially completed and setup to the 3 x 27in HD monitors
PS. Each loop has a round DD resv that mounts to the piping on the back above the EK rad. To add fluid I simply need to remove the plug, screw in the resv., and pour not shown in any of these pics. Quick disconnects so the cards and/or CPU and be swapped out easily
Old 04-07-2011
Looking sick Dawgg ...........
That is a big case
Old 04-07-2011
GeorgeStorm's Avatar
Very nice, how'd you find the case? I find it so nice to work with when it comes to water
Old 04-07-2011
Thanks dudes.
The Corsair 800dD is rather huge - heavy too cause it's made out of steel. Unfortunately it wont fit the big boards like the 4-way SLI cause they're too long. Otherwise a ton of room to work with.
I got mine at Microcenter on sale for about $239, list is $299. The egg carries them but I don't know what theu're asking for it.
Kind of towers over that little mid tower don't it :rolf: (I use the psu in the little one to run the loops during filling and testing)
Old 04-07-2011
Got mine half price, just aswell since they're over £200 new over here :O
Only got a single loop atm, although I do like where you've got the 120mm down at the bottom, tempting....
Old 04-09-2011
Yeah, that 120 slips in real nice, might require a modular PSU though cause the cables make it tight. I've seen mods where people cut out the lower HDD rack, cout out a portion of the bottom plate of the case, and, mount a 2x120 horizontally down there. I'm using 1 of the 2 lower HDD racks for my storage and backup disk though and really don't miss the extra 120.
I am now in deconstruction phase awaiting a new mobo that will arrive on Monday. The quick disconnects came in real handy as all it took was 4 quick twists and the video card and water block were free. Have another one coming in Monday for that last tube that connects from the mobo to the back rad. Then I'll be able to quick remove the entire mobo whenever I want without draining any loops
A few pics during the waiting period. Note how the output of the water block plumbing is sitting horizontal to the CPU block and very low to the board. It sits right on top of the HS for the VRs/moffests which I'm hoping will help keep those cooler as well In the pics above, a 92mm fan sits between this and another quick disconnect
Note: the Kryos mounting kit from the factor is FAIL. I used the back plate but had to buy 2 in 6x32 course thread screws and use a Kingpin pot screw down kit with the stops, springs, and thumb screws. Works great this way!
Old 04-09-2011
two more
I have 3 580s, 2 now have water blocks on them and one is air cooled still.
Thought was to just go straight to LN2 with the third but now I think I'll put a water block on it too (have it inhouse), run all the benchies with cold water, then freeze which ever card I determin is better
Old 04-09-2011
That is a big case
Thanks WD.
Once this gamer is done (I have 3 x 27in ASUS monitors for it) I'll turn my focus to the sub-zero lab downstairs. I now have TWO LABS ... is that cool or what hahahahahaha. The lab in the pics above is on the second floor
Old 04-09-2011
indeed, killer killer water coolin
Old 04-09-2011
Last ones today
But I figured no foto archive of this build would be complet without these pics, so .....
First the front Koolance Resv - I love this resv Holds two resvs and two Dlaing D5 pumps in two bay spaces. top screws can be used for filling and front screws are great for bleeding, but.... muhahaha I've found a better way to fill and bleed
The back exterior plumbing is multi-operational. First pic shows it all battened down for gaming once the loops are full and bled free of O2. To fill and bleed, each loop has a mount for a round DD resv that easily screws into place..
Simply genius wouldn't you say :
Last water build I do without being paid to do it though, what a PITA
