Overclockaholics Forums » Hardware Section » RAM » Corsair Dominator Gt CMG6GX3M3A2000C8
Old 04-02-2011
Spank's Avatar
Spank Spank is offline
Junior Addict
Spank is just getting started
Default Corsair Dominator Gt CMG6GX3M3A2000C8
Hello
So far i can overclock there babies only at 1600 8-8-8-24 2t stable,i have tried the xmp profile at asus rampage 3 extreme but after some benches,games etc the blue screen of death always appears.
Do you have any experience with those babied and what timings and mhz you have achieved to have it stable ?
Intel Core i7 975 Extreme Edition 4.3GHz 1.375vcore|Asus Rampage 2 Extreme|Corsair Vengeance LP 12GB DDR3-1600|Asus GTX570|Creative X-Fi Titanium-Fatal1ty|Intel Postville 80GB SSD,300 GB WD Velociraptor,2X640GB WD|Silverstone Strider 1500W|Samsung Syncmaster P2370|Coolermaster Cosmos 1000|Razer Lachesis Precision 3G Laser|SteelSeries 5H v2|
Old 04-03-2011
Spank's Avatar
Junior Addict
Update : It seems i can get them stable at 7-7-7-24 2t 1880mhz with 1.65 voltage and 1.60 at QPi. I have pass test with memtest even at 2005mhz but if i stress it a lot with linx im getting blue screen.
What its weird is that after the blue screen my cpu is at 76c and im for a reason that why i have the blue screen and not from memories hmm
Still trying to figure out whats the exact problem
Old 04-03-2011
That qpi is much to high, if anything try 1.75 on the vdimms.
Old 04-03-2011
Spank's Avatar
Junior Addict
I asked corsair and said 1.60 at QPI and 1.65 voltage.
How much qpi should i give im not sure some said 1.35 others lower than that,as for vdimms you mean to give 1.75 instead of 1.65 hmm isnt too much ?
Im trying to find out if its the memories or the cpu temperature that cause the blue screen because as i said the memtest is ok
Old 04-03-2011
Try bumping vdimm in small increments to say 1.72 if anything. The IMC on the chip is probably screeming when you run linx which may lead to degradation of the chip. Are you tryin to get benchmark stable (super pi 1m and 32m, pifast, wprimes) or going for 24/7 stable?
Old 04-03-2011
Spank's Avatar
Junior Addict
I want 1st to find my settings for 24/7 stable as higher i can go from ram side and then i can play with the rest for better benchmark results than that.
Old 04-03-2011
Possibility of overstressing that chip using linx to push to tits end of 24/7 stability. Try seeing if it scales with vdimm in increments. Can you list all your votlages?
Old 04-03-2011
Spank's Avatar
Junior Addict
As soon as i go home i will take a picture of bios
Old 04-03-2011
prime95, linx, aida64, all these stressmarks, use them as a tool, not a rule
Old 04-04-2011
Spank's Avatar
Junior Addict
Here is my bios
