Overclockaholics Forums » Hardware Section » Motherboards » Intel » Decent board for 970
Old 03-06-2011
Default Decent board for 970
Buddy of mine up in Canada got a 970, he is running an old GB board and having problems clocking.
What are some good recommendations for 32nm hexacores?
I know R3E is popular but he might want some other boards at different price points.
Thanks
Old 03-06-2011
crio's Avatar
crio crio is offline
Dont know how Giga X58A-OC will clock BCLK.....But seems a rock solid mobo
Crio OC
Old 03-06-2011
freeagent's Avatar
freeagent freeagent is offline
freeagent is just getting started
Thanks hombre
What Im after is a board that isnt as finicky as my current ud5 rev1 is. I would also like a board that has very good voltage regulation, as this one has soo much sag and droop, and llc has never worked properly with it . I have questioned my oc skills a few times because of this dam board
Any suggestions would be very much appreciated
3770K @ 4400 1.215v/True Spirit 140 Power/TY-143|Asus P8Z77-V|12GB G.Skill TridentX+RipJawsX @ 900 9-9-9-24 1T 1.6v|EVGA GTX 980 Classified 3988 @ 1497/2001|CM Silent Pro M2 850|Fractal Design Meshify C
X5690 @ Stock+Turbo/Le Grand Macho RT/TY-147B|Asus Rampage III Formula|12GB STT Chrome+OCZ Reaper @ 667 6-8-6-24 1T 1.6v|EVGA GTX 970 FTW ACX 2.0 @ 1404/1753|TT SPM850|Fractal Design Define R4
Old 03-06-2011
freeagent's Avatar
I think x58a is already like my board, just tweaked and improved?
I would prefer something with a different pci-e layout if possible
Old 03-06-2011
x58a is the board developed ground up for overclocking, hicookie was involved in the process.
Old 03-06-2011
freeagent's Avatar
Yeah I saw that, I think it had a different name tho. Gigabyte has the rev1 boards, then they added an "A" to the Rev2 boards. ie: X58 UD-5 then the newer X58A UD-5
Old 03-06-2011
What boards did you have in mind already? price range? pci-e needs?
Old 03-06-2011
freeagent's Avatar
Im not really concerned about the price too much, the only board I have been looking at is the R3E pretty much I have been out of the loop for a litle while, and am now just getting back into the hobby, so Im not up on whats good, and whats not. Right now my cpu is aircooled, but when I do get into the cold stuff, I would like a board that can take it.. Im looking for a good daily driver, with nice manners, and good performance, but Id also like to take it to the track now and then and beat on it
Old 03-06-2011
You might take a look at the black edition of the RE3 when it comes out.
Old 03-06-2011
freeagent's Avatar
See, I did not know the board existed until you mentioned it
Edit:
Thats a fitting board to kick off the end of an era with s/1366
