Overclockaholics Forums » Hardware Section » HDD's & Other Storage » How do I install XP w/sata set to AHCI mode?
Old 02-18-2011
ny_driver's Avatar
Default How do I install XP w/sata set to AHCI mode?
I was told that for optimum SSD performance the OS should be installed in AHCI mode.
I can't get it to work. Probably just need some guidance.
I get either no storage device detected or BSOD when I try installing in AHCI mode.
I searched the net and found instructions for changing it to AHCI after installing in IDE mode using regedit then bios, but the registry key referred to does not exist.
http://forum.corsair.com/v3/showthread.php?t=85660
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
