Overclockaholics Forums » Welcome to Overclockaholics » Suggestions » What do you think about a grinders guide per card in sanctum
Suggestions Have An Idea...
Old 02-17-2011
Default What do you think about a grinders guide per card in sanctum
I would like to have a template for every graphics card that shows what tweaks you used what drivers worked well, vmods, pics, LOD, OS etc.
All posts in the thread will be updated in the first post and cleaned to no discussion only helpful info.
Thoughts?
I can throw together a template in a minute
Old 02-17-2011
ny_driver's Avatar
Sounds like a fine idea to me, I always need some extra help.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-17-2011
example
::ATI HD 4870 1GB::
-Vmods-
-3d01- 9.* drivers..Windows XP
d3d overrider
LOD Approx 2-3
-3d03- 9.* drivers..Windows XP
-3d05- 9.* drivers..Vista/Win7 x64
-3d06- 9.* drivers..Windows XP
-Vantage- 10.* drivers..Win7 x32
-AQ3- 10.* drivers..Win7 x64
ReName aquamark.exe to 3dmark03.exe
d3d overrider, LOD can be increased to steal a couple extra mhz
-Tips-
Vmem mod, not necessary. Does not scale with voltage
Old 02-17-2011
ny_driver's Avatar
Okay so lets do the 4890 next please.
New Ride:
Rampage 3 Extreme
3x2GB cas7 DomGT
Old 02-17-2011
hehe I would if I had one!
Old 02-17-2011
GeorgeStorm's Avatar
Ooh, this is a brilliant idea.
Will contribute what I can to the 8800 series, since I'll be working on them a bit over the coming weeks.
Old 02-17-2011
Awsome idea, but beastly to maintain as results may vary
It would meake a great reference source for sure
Old 02-17-2011
yes just as a starting point im thinking. Instead of going through driver after driver etc
I was thinking a new thread for every card, just needs its own section
Old 02-17-2011
Awesome idea Al.
So much good info on the forums would be great to have an easy to read section for quick reference.
Old 02-17-2011
thanks any other things you would like to see included?
